Dyson DC16 Root 6 Bagless Handheld Cyclonic Vacuum Logo
Posted on Aug 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My dc16 dyson root vacuum stopped working abruptly with no indication of a weak battery, the charger does not show a charge on battery. usually the vacuum slowed before it stopped with a dead battery, any suggestions
Think Crucial
Level 3:
Master:
  • Dyson Master 894 Answers
  • Posted on Jul 23, 2017
Think Crucial
Dyson Master
Level 3:
Master:
Answers
894
Questions
0
Helped
710809
Points
8395
Hello, this is Ava with Think Crucial.
Most Dyson vacuums have a built in safety system that stops the machine if it begins to overheat. This usually happens because the filter needs washing or your machine is blocked. If your machine turns off on its own, unplug it and leave it for at least an hour to cool down. Remember to check the filter and look for blockages before re-starting.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
5 Related Answers
richroth
Richard Roth
  • 9472 Answers
  • Posted on Jul 23, 2011
SOURCE: I have a Dyson model
If you have a voltage test meter, check to see if you any voltage at the charger. If you have no voltage at the charger after doing the check, you will need to replace the charger. I have a few of them go bad over time.
Anonymous
  • 389 Answers
  • Posted on Apr 18, 2009
SOURCE: Removing the battery
The battery is located at the bottom of the handle. To release it, press and hold down the button on top of the battery case (it has 3 ridges on it). That releases a catch and you can then slide the battery out to the rear.
Anonymous
  • 389 Answers
  • Posted on May 17, 2009
SOURCE: Dyson DC16 Handheld Vacuum Cleaner Manual
Yes! Go to www.dyson.com/support. Click on "using your dyson", then (next window) on "select your model", then (next window) on "select your model" again, then (next window) on "DC user guide". And there you are, you've got a copy of the user manual.
Please remember to rate this response. Thanks!
askdyson
AskDyson
  • 2572 Answers
  • Posted on Aug 01, 2011
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: I put a new battery
    Sorry to hear you're having difficulties with your DC16. Although your cleaner will no longer be under its original 2 year warranty, the new motor assembly would be covered by a 12 month warranty if you purchased it directly from Dyson. As long as the cleaner has been used in accordance with the terms and conditions described in the manual, we should be able to replace this for you.
    Alternatively, we could arrange to have the cleaner returned to us for further inspection.
    In either case, please get in touch with us directly so we can discuss the issue further. You can call us free on 08002980298 - our Helpline is open from 7am until 10pm, 7 days a week. We look forward to hearing from you.
    Kind regards,
    Jack
    Dyson Customer Service
    lex brooks
    • 14 Answers
    • Posted on Nov 11, 2011
    SOURCE: I bought Dyson DC16 in
    Your battery is losing voltage too quick. It has probably developed a 'memory'. Dyson claims that their handheld has the best suction out of all the handhelds out there. In order to maintain that claim the circuit board will shut off power to the motor when the voltage drops below adequate charge for full suction.
    We need someone who can teach us to bypass that part of the circuit so it won't cut power to the motor or you need to get a new battery.
    Shorting the battery like an Aircraft battery then re-charging won't fix it.
    I have a Dyson DC16 handheld and the battery does not hold a charge.
    I have the same vaccumm with the same problem, went back to exchange it and the same thing happened, I usually get about 10-15 minutes non stop out of the battery, I read that the battery memorizes the first charged time and then will only charge for that long. Did you happen to charge it 24 hrs?
    1helpful
    Dyson dc16 battery not hold full charge, all three lights stay on indicating a full charge.
    If you're concerned that your DC16's battery doesn't seem to be working correctly, please get in touch with us directly. One of our experts will be happy to run some troubleshooting over the phone with you to determine whether the battery needs replacement.
    You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
    Kind regards,
    Jack
    Dyson Online Customer Support
    1helpful
    Vacuum does not charge. According to the Dyson website, the blinking LED's indicate that a new charger was needed. We purchased a new charger and the product still will not work.
    Sorry to hear you're having difficulties with your DC16. It's probably best if you get in touch with us directly so one of our experts can identify the exact cause of the issue, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
    Kind regards,
    Jack
    5helpful
    2answers
    I Need A dyson hand held battModel DC16 12097 model 282-US-A35458 21.6 1080 MAH All I can find is the 1500 Mah
    I didn't understand what you need exactly, but anyway, you can find both of them on amazon (the entire vacum, or just a battery 1500Mah). take a look on following links:
    1. entire vacum: Dyson DC16 Root 6 Handheld Vacuum Cleaner
    2. just battery: Pwr 1500mAh Extended Capacity Battery for Dyson Dc16 Root 6 Vacuum Cleaner...
    1helpful
    I have a dyson dc16 and when i pull the trigger all three lights come on but nothing happens from that point?
    it needs charging . and if the lights dont light when you put it in the charger somthing is wrong with charger or battery
    1helpful
    3answers
    My dyson dc16 is not holding a charge.. maybe I need to replace battery
    Hi its Darran at Dyson.
    If you call our Helpline they will be able to run through some simple checks to detemine the cause of this issue.
    Please call 0800 298 0298 (UK) or 1866MYDYSON (US).
    Kind regards
    Darran
    10helpful
    My DC16 will start and then stop. I have to take
    My DC16 also had charging problems. I called Dyson and they sent a new charger. The old charger only produced 23.6 volts DC, not the rated 28 volts DC. The new charger has a thicker round wire and produces 28.1 volts DC. Put a volt meter on your charger terminals and see if it is producing enough voltage to fully charge the battery, 28 volt DC. If not you need a new charger.
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Sean Wright
    Sean Wright
    xxxxxx xxx
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
