Lexicon MC-1 Amplifier Logo
Posted on Aug 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need diagram/schematic for Lexicon MC 1 power supply
Anonymous
Level 3:
  • Master 4,234 Answers
  • Posted on Aug 19, 2010
Anonymous
Master
Level 3:
Answers
4234
Questions
Helped
1564270
Points
12312
As far as I know, Lexicon schematics are only available to authorized service centers. Can you describe the problem that you are having? Perhaps we can assist you with the repair?
Dan
  • 3 more comments
  • Anonymous Aug 19, 2010
    Just confirmed this with my Lexicon contact. Schematics are NOT available outside of authorized service centers. I do have access to them though. Please indicate what the problem is and I'll try to get you sufficient info to repair.
    Dan
  • Anonymous Jun 22, 2013
    Hi Dan - Are you still out there? We're trying to diagnose a lexicon MC1 power supply failure - the large capacitor caught fire, and we want to see the schematic to see what other components may failed to cause a problem.
    Is this something you can or would be willing to help us with?
  • Kevin Z
    Kevin Z Feb 25, 2014
    You can buy a whole new power supply from Mouser for $54. A dozen philips screws, two header connections and you're done.
  • Kevin Z
    Emerson NFS40-7610J or equivalent
Trouble during the upgrad of lexicon MC-12
Try on a different computer , if it still get stuck at the same point bring the amp to sevice shop, they will reinstall the firmware
My lexicon mc 12 pre amp won't power on. The lead
There may be a secondary fuse inside the unit, if not the problem will be in the power transformer, if you are handy with a digital post back and I will give instructions on testing the transformer.
Where can I find reliable, cost effective repair to my lexicon mc12 HD?
A place called "The Service Bench" located in Massachusetts is an authorized service center for Lexicon. Contact them.
Dan
I get error code c-0046 and now machine will not work. What do I do?
C0046: Fusing Cooling Fan Motor /1’s failure to turn
Relevant Electrical Parts
Suction Fan Motor (M12) Control Board (PWB-MC)
Step Action
WIRING DIAGRAM
Control Signal
Location
(Electrical
Component)
Check the connector of motor for proper connection
and correct as necessary.
Check the fan for possible overload and correct as
necessary.
M12 operation check PWB-MC PJ18MC-9 (LOCK)
PWB-MC PJ18MC-7 (REM)
6-P
4 Change PWB-MC — —
Fusing Cooling Fan Motor/1 (M9) DC Power Supply (PU1)
Step Action
WIRING DIAGRAM
Control Signal
Location
(Electrical
Component)
necessary.
3 M9 operation check PU1 PJ17PU1-5 (LOCK) 2-K
4 Change PU-1 —
1helpful
Lexicon DC-2
DC-1, DC-2 an MC-1s have the same power supply. The power supply usually lasts about 5 years before it goes. A New power supply is usually about $ 65.00. There is usually a $300.00 LABOR FEE. Check out THE SERVICE BENCH in MA. Phone number is 781-769-4338.
2helpful
MC1 Switched Power Supply
Hi Hansjo. You may find that if one capacitor has failed, then there may be more. If you see any signs of bulging, leaking, or pushing the bottom out of any caps, then It is a good idea to just change them all. For the small expense, it is worthwhile knowing that your power supply has fresh caps. Try the amp and then see how it goes. If you still have problems, get back to me here and we can talk about it more.
regards
Graeme
Top Lexicon Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Lexicon Audio Player and Recorder Expert? Answer questions, earn points and help others
