Sewing Machines Logo
Posted on Aug 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to make a button hole with the Elna Quilter's Dream 6600?
Anonymous
Level 2:
New Friend:
  • Expert 54 Answers
  • Posted on Aug 19, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
54
Questions
Helped
12199
Points
103
It has a built in button hole, check your manual and put proper foot on machine.
1 Related Answer
Tally Girl
Tally Girl
  • 1134 Answers
  • Posted on Nov 02, 2011
SOURCE: do I use a twin needle with my narrow pintucking
if you want to sew pin tucks, then yes, you could use that foot providing the hole is large enough for the two needles to pass through. Twin needles come in 4mm gap and 2.2mm gap so just check that it will fit. When using a twin needle, there is a lot of heat created so it is always important so sew slowly, going too fast will cause the needles to break.
Also, you should check on the twin needle type, modern machines now using a twin which is slightly offset, the block colour is usually a dark brown/red colour. Your machine may have come with a twin needle in the needle selection so take a good look at it and see if it is an offset one, then make sure you buy replacements of the same type.
THe pin tucking foot allows you to keep rows of pintucks lined up, it will have grooves in the base that you can run the previously stitched pintuck through to keep even distances. Best on lightweight fabrics like cottons, lawns, batiste etc. You'd probably go for the narrow 2.2mm twin needle to get a nice fine tuck. I like to press each seam after stitching too to give a sharp tuck.
1helpful
Is it true that Elna Quilter's Dream Pro 7200 doesn't need oiling? Looking for a service manual.
If your machine is computerized, it is very important to oil only as instructed in the owner's manual. Oiling otherwise could damage the machine. Of course, it is recommended that every machine be taken for professional service every year. The technicians know how and where to service the machine. Self-servicing the machine to save ~$100 could cost thousands.
Oil or not an Elna 6600 quilters dream 2 ?
Since it is a computerized machine, oil as directed in the manual. Oiling in the wrong place could damage the machine.
Where is the back stitch button on a elna 6003
If you have the owner's manual, it is supposedly called a "Reverse Key."
Elna United States Sewing Elna 6003
Look for a button near the needle with an arrow pointing backward.
2answers
Lena sewing machine 6003 how old?
Hi, I'm Julie. Is the model of your Elna machine called Lena? Is your machine an Elna 6003? Is your machine an Elna 6003Q?
My elna quilters dream machine has 84o test mode on display and I can't select other stitches
you might think about having the machine check to see if there is something wrong with the motherboard
Do I use a twin needle with my narrow pintucking foot on my Elna quilter's Dream 2 sewing machine?
I have moved house and lost my manual for my Elna 6600 Quilting Machine - Can I get a new manual or perhaps a copy until I find my own manual. thank you Jules
Well you may please follow the link below to get your manual -
http://www.sewingnz.com/products/Elna-6600-Sewing-machine-instruction-manual.html
Good Luck!!
Thanks for using FixYa!!
I have the Elna 6600 series Quilters Dream . I broke a needle because I had the incorrect foot on. When it "hit" the "Turn off for Safety Purposes" message came on.... then E2 . I...
Does your manual have a troble shooting section at the back and if so, what does it indicate for the E2 message?
Have you replaced the foot with the correct one and gone back to a straight stitch setting?
I'd turn it off, remove the needle plate and bobbin, clean everything out, check that there isn't a broken bit of needle anywhere, then reset everything up, turn it back on and try again with the standard foot.
2helpful
Burned out bulb.
Generally on an Elna there's a little hole on the very top of the sewing machine directly above the bulb.
Pushing a long, skinny stick (like a screwdriver,) down into this hole will push the lightbulb and socket assembly down to where you can actually access the bulb without having to try to skvoosh your fingers into the tiny space.
-R
Top Elna Sewing Machines Experts
Mike Cairns
Mike Cairns
SmartAviator
SmartAviator
Ngoro
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
