Anonymous Posted on Aug 18, 2010
I have a GPX model S7694 Mini Shelf system The tape player and radio work. The 5 CD player and record player do NOT work. The turntable on the record player turns until I put a record on it!
  • 1 more comment
  • Anonymous Aug 20, 2010
    I tried what the first expert suggested and it didn't work.
  • Anonymous Aug 21, 2010
    What would be the next step - try and find a repair shop to work on it or? I inquired locally and no one works on those kinds of things anymore! ;-(
  • Anonymous Aug 26, 2010
    Thanks. Sounds good, but I am afraid a little beyond my capabilities!
    I may try to buy a CD cleaning disc and see if that helps the CD player.
Level 3:
  • GPX Master 17,130 Answers
  • Posted on Aug 21, 2010
GPX Master
Level 3:
Answers
17130
Questions
0
Helped
3631848
Points
52372
Possible that the optical head of the Cd player id dirty and so does not read the data on the CD. Open and clean the optical head as if the fault remains it is the failure of the optical head. Make sure that the loading is happening well and the optical head moves up to detect. confirm if the same type is available to attempt a change, Need to take precaution to do the work with care. Do not forget to remove the solder short to prevent static damage on the new head. Use of good tools is recommended.
Hold teh turntable to see if it stops then check if the turntable drive is belt driven or servo. failure of the belt can stop the table to stop on load. If not the servo is switching off the motor when the arm moves, could be the servo cutting off with the cut off end switch. Check servo drive to turntable.
Hope this tip helps.
Anonymous
Level 3:
  • Master 2,926 Answers
Anonymous
Master
Level 3:
Answers
2926
Questions
0
Helped
1004728
Points
9623
The belt is slipping, causing to much tension on the drive system. I have not found replacement parts or a serive diagram for the shelf system.
  • Anonymous Aug 25, 2010
  • Anonymous Dec 15, 2010
    @LEDSLED378: the system is not belt driven: it is gear driven. Facts are, GPX doesn't make a quality system.
Willard Broughton
Level 2:
Sergeant:
  • Expert 252 Answers
  • Posted on Aug 18, 2010
Willard Broughton
Expert
Level 2:
Sergeant:
Answers
252
Questions
0
Helped
41584
Points
715
Your Electric motors are not getting enough power from your power suppy go in and make sure all the wires are plugged securly into their connection. This should solve your problem.
  • Anonymous Aug 18, 2010
    Unfortunately it did not work. The system is plugged into a power strip and I turned the power strip off and then on, plugged the power strip into a different outlet and changed the outlet on the power strip where the GPX was plugged in...still no luck. The other item on this power strip works, so it doesn't appear to be a bad power strip.
  • Willard Broughton Aug 21, 2010
    Hi, this is Willardbr34 the first expert you consulted. If you look on the computer and go to the yellow pages website look under CB Repair in your area. These guys live and breath radio they will fix it for you.
Had a GPX S7794 for years, now having trouble w/ turntable. Turns on by moving tone arm right, but if moved left to try to place it on a track towards the end of the record, turntable shuts off.
What happens is that a mechanical system under the turntable pushes on a micro switch to operate the motor. Clearly either the mechanical system has moved out of position or the switch has. You take the bottom off the turntable and see what happens when you move the arm.
No sound from CD player. The turntable, radio & cassette work fine.
Can't get video to work so bose works with tv sound
Can't get video to work so bose works with tv sound I needed to reset the power on my bose and instead of unplugging the power cord, I unplugged the audio/video jacks because I couldn't see behind the
I need a manuel for a GPX 5 compact stereo home music system
If this is what you are looking for? you could have found it with Google.
Just click the link:
http://pdf.crse.com/manuals/2067346111.pdf
Cd player will spin discs but no sound comes out
The laser assembly has failed, buy a CD cleaning fit and follow instructions, this may breath more life, if not! replace the player not cost effective to repair.
I lost the english version manual just want to know how to record from cd to tape
Try this, select "cd" as your source, and load a cd. Press stop.
Then load a cassette, press play and record for the tape, and then press play for the cd player.
http://www2.panasonic.com/consumer-electronics/support/Audio/Home-Theater/Mini-Systems/model.SC-AK78
Hope this helps.
6helpful
How to turn on turntable on Philco Turntable CD Player
Just pull the arm back a little bit, the turntable should then start.
Auto timer
what is the model of the radio and i can surley find out for you.
Top GPX Audio Players & Recorders Experts
SmartAviator
SmartAviator
 Grubhead
Grubhead
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
