Question about Toshiba REGZA 47HL167 TV
Can't remove the base/feet - i want to mount on the wall. if there are screws, we can't find them - tried allen wrench, phillips, etc., no luck. thank you
  • 11,361 Answers
See page 5 of the owner manual:
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat,
cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface.
Note: Extreme care should always be used when removing
the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose
the pedestal stand screws. The jack pack cover can be removed
without tools.
3) Remove the five screws shown in the diagram below. This will
allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal
stand in place, remove the pedestal stand from the TV by
sliding the pedestal stand away from the TV.
http://www.tacp.toshiba.com/tacpassets-images/models/47HL167/docs/47HL167_om_e.pdf
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Aug 19, 2010
  • arapaho3x6 Feb 08, 2011
    What happens if the jack pack is not removable but rather one piece with the rest of the rear cover?
6ya staff
SOURCE:
Removing the base stand
Hello; I am a Sharp service center. Every one of their sets I have seen so far has 4 Allen head screws that are recessed to mount the base to the set down near the bottom. You will probably need to but a set of Metric Allen wrenches to get the right one. The sets are all sold with the correct wrench. It is L shaped. Good Luck, John
Nov 21, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
How does the holder detach? Allen wrench,star, push with a screw driver?What do you use to remove the holder from the wall?
there is no set screw or allen key for this. It is mounted in the anchor bolt by use of a mounting screen, pressed in until it clicks and difficult to remove
Nov 19, 2009 | Moen YB2808 Eva Paper Holder - Chrome
Honda CRV rear view mirror removal
There are three ways usually...
You'll need to remove a screw securing the base onto the mount (usually on metal bases)
You'll need to lift up a clip on the bottom of the base and then slide the base off the mount (usually on plastic rectangular bases
You'll need to twist the base about 45 - 90 degrees so that it slips off of the mount (usually on bases that are circular)
Nov 12, 2009 | 2004 Honda CR-V
Need to change a keyless chuck
open jaws for large size bit.look in bottom and there will be a screw slot or phillips head screw or possibly an allen head screw.remove this,by possibly turning clockwise. and then chuck up a large allen wrench. try removing the chuck by tapping wrench with hammer. this may be threaded on counterclockwise.have to try both ways.
Aug 28, 2009 | Craftsman 19.2v 3/8"drill/driver W/ Work...
Hansgrohe 41533 wall mounted soap dish install
I had the same problem with a Hansgrohe set screw on my toilet paper holder. Thought an allen wrench would do to open it but it does not work, I had to use the end of a pointy dinner knife to coax it out, might have also used a flat edge glass repair screwdriver also to get it out. It almost look as if it was "stripped" in the opening. I'm now trying to find a replacement set screw and came across this page. Hope that helps.
Apr 15, 2009 | Hansgrohe 41535000 Axor Uno Toilet Brush &...
Removing television base
You will need a phillips head screwdriver. There are four screws on the back of the TV that go into two rather long "legs" that go a few inches into the bottom of the TV. Just remove those screws and lift the TV off the stand. If you have your owner manual it will show you exactly where the screws are located otherwise just look for the heads of phillips head screws.
Mar 20, 2009 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
Can not remove the stand to mount it on the wall
If the Aquos 46 is anything like the Aquos 42, the monitor is attached to the base with machine screws (bolts). They are located in the lower back portion of the monitor, probably need an Allen wrench to loosen and remove. Once that is done, the base can be removed from the monitor. Best way is to lay the monitor face down on a tabletop padded with foam, a quilt or blanket, etc to protect the screen as you work. Remove the stand from the monitor, not the monitor from the stand; it is easier and safer that way.
Jan 18, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Need to remove the base so we can put the monitor on a wall mount
The base is removed by peeling off the feet pads to reveal screws that need to be loosed to reveal more of the base removal screws.
Dec 04, 2008 | X2Gen Computers & Internet
Trying to remove the filter screen to see if something is blocking
Try a Torx screw driver. It looks like an Allen but it is a star shape head.
Mar 29, 2008 | Kenmore 15872 Dishwasher
Toshiba 52 inch flatscreen
I have just completed removing tha base from a Toshiba 52 inch HDTV. There are 5 screws in total. Three about 8 inches form the base and another 2 about 4 inches from the base in the arrangement shown below
(X) is a screw
(l) center line
X X X 3 screws 8 inches from base
X l X 2 screws 4 inches from base
______l______ The base
Keep your feet clear as your undoing the last screw..the base slides out vertically downward and weighs about 10-15 pounds so keep your the toes, fingers etc safe. The risk of being sued may explain why Toshiba didn't this publish in the US manual.
Feb 24, 2008 | Televison & Video
Toshiba REGZA 47HL167 TV Logo
1,721 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
