If you are having CD write problems test to by doing a backup of the hard drive. If you are able to burn backup then your CD writer is working. That means you probably haven't mastered the song or songs you are trying to burn.
On most CD burning recorders you need to master the song in order to make it writeable to the CD. Then when you go to the CD. Or data menu it will bring up the songs that are ready to burn. Also there is a difference between CD/r. CD/r/rw and CD/rw make sure you CD burner is exactly the same as the CD
MICHAEL SCOTT: YOU PASSED ALONG SOME GREAT INFORMATION BUT IT ONLY GETS ME HALFWAY THERE...
I HAVE ALL THE NECESSARY CABLES HOOKED UP. DO YOU HAVE TO RECORD MY SONG FROM THE 1180 TO AUDACITY OR WHAT?...THIS IS ALL NEW TO ME AND IT MAY WORK BUT TELL ME HOW TO RECORD FROM THE 1180 TO AUDACITY.
THANKS...GEORGE SLADEK
SOURCE: No CD writer for Boss BR-1180
Hey mike yeah you can hook a regular cdr drive to the ribbon but the problem is if its not a slim it most likely wont fit inside the unit. Also the built in c.d r is way over rated mine has it and I still bounce it all onto my computer and then burn it from there. The one on the br-1180cd burns very quiet.
SOURCE: MY Boss br 1180 ,disk error
The Humming Is Normal When The Unit Is Not Properly Placed On Something That Is Level Make Sure You Find A Flat Part On Your Dresser Or Wherever It May Be. I May Add DO NOT EVER UNPLUG THE BR-1180 WHILE IT IS RUNNING Unless You Like Losing All Your Data. As For The Hard Drive Problem Call Roland They Are Extremely Helpful. It Is Unlikely That Your Whole Hard Drive Is Fried
SOURCE: What do I need to burn a cd from my pc with the br 1180
This Is real simple grab a cable that goes from rca jacks to a headphone jack then plug the rca jacks into the br-1180's audio out jack and then plug the other end into your computers mic port.
Download Audacity From www.Audacity.com and then use it to capture you audio and then you can burn that when complete.
Its real simple I do it all the time even though I have the br-1180cd the cd burner burns real quiet so I don't use it. The cable can be bought at radio shack, best buy, wal-mart and I have even seen them at 99 cent only stores.
If you have more question let me know This Is my main unit so I know a lot about it.
Sincerely,
Michael Scott
SOURCE: BR-1180 Cd will not burn CD's does it call for
Don't know if this unit is sensitive to the type of CD, but my Phillips recorders will ONLY burn the "Music CD's" (harder to find, more expensive). Read up on the difference of regular vs Music CD's. ALSO some recorders will not burn disks rated at lower or higher rates.
SOURCE: BR-1180 freezing & high-pitch ring
Check your power supply to the unit. Low voltage COULD cause this.
Also make sure a setting is not "looping" the audio back into itself.
