Cameras Logo
Posted on May 02, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fugifilm FINEPIX A205S When I switch on the power the zoom lense comes out but the screen is blank and when I try to turn the power off nothing happens and the lense doesnot retract.
  • Betsy2 May 02, 2008
    I dont understand t/it got Jammed
Anonymous
Level 3:
Guru:
  • Master 1,894 Answers
  • Posted on May 02, 2008
Anonymous
Master
Level 3:
Guru:
Answers
1894
Questions
13
Helped
563146
Points
4850
Has t\it got jammed..
  • Anonymous May 02, 2008
    has the lens got jammed?
    remove the batteries from the camera and leave it for one hour. then again put the batteries and thebn use it.
    tell what do you observe in that
Finepix j27 When the camera is turned on "Zoom error" message appears and lense is stuck in an extended position. When the power is turned off, the lense remains extended. Do you know how...
hi, Zoom Error occurs when there the lenses are not able to move and something is obstructing the movement like some dust or sand grains etc., to dislodge the obstructing particles try tapping the lense side corner of the camera on a table top lightly (not too hard please, as the lense and autofocus combination is quite fragile) a couple of times in switch off mode and trying to power on after every 2-3 taps.
or you might send it out to a service centre, the charges are generally just the serviceing charges as no new parts needed.
hope this helps
cheers
May 05, 2011 • Cameras
1helpful
Too have FinePix F420 Digital Camera and it works only in "Play mode". If the mode switch is put to either Photomode or Video, the lense comes out and with just a flicker, the camera stops and...
All you can try is to remove the batteries, wait for about 5 minutes the replace them.
If it's not working, it seems to be a problem either at the CCD/CMOS sensor, or at the lenses zoom mechanism.
1helpful
I own a Fugifilm digital camera that is frozen
It swounds like the system battery may need replacing.
This is separate from the usual batteries that you change and charge up. look on the base of the camera to find a round disk with a groove in it. Inside is a button battery CR2032 or similar. This is the battery that controls all the setting you have set for brightness contrast number continuity etc etc. replace this noting the way it came out + up or down and i think your problem may be solved for abot $4.00
please rate my help++++Thanks for using FIXYA
May 08, 2010 • Cameras
1helpful
Fuji finepix a600
If the camera was on when it was dropped you probably jamed the lense coil. The lense coil is what helps the camera smoothly pull in the lense and back out. Now, just to specify, what exactly are you having a problem with? Will the actual lense not go back into the camera when you turn it off; or can you not get your camera off zoom?
Let me know~
Olivia
Fuji FinePix F700 LCD & Zoon Lens
Is the battery fully charged? Or is the battery near the end of its useful life? Some batteries hold a charge better than others-- I have 2, both used well, and one seems to last longer than the other...
Finepix A400
If the "!ZOOM ERROR" message is displayed on the digital camera, switch the camera off and on again 2 or 3 times.
If this does not clear the error, take the camera to your nearest FUJIFILM Service Station for testing and repairs. Problem may caused by lens zooming gears stuck.
2helpful
Broken Zoom on Fuji Finepix F470
Try turning the power on and gently pulling the lens outward as it powers up. This may force the gears to re-align themselves. Use "fingertip" pressure only. Don't force it excessively. Also try turning on, and then applying slight pressure to the front of the lens while you power it off. You can also try rotating the lens barrel segments while it powers up or shuts off. Sometimes either can get the lens back on track.
3answers
Zoom lense stuck
The only solution is to replace the lens module.that module is very costly. hope it help
Zoom lens will not completely come out
It needs a service -contact the Fuji website technical support.
3answers
Fugifilm FinePix A303 Digital Camera
hi this error indicates that the delicate mechanism of the zoom had gone bad there is no way you can fix this by yourself leave it for an expert have a good 1
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
