Verify your fans are for the CPU and case are moving. You can remove the Pc cover and turn on the Pc. Watch the cooling fan on top of your CPU heat sink, it should begin spinning when you turn on your PC. If it doesn't then with the PC unplugged, make sure the connector for the fan is seated properly. From behind the PC you should be able to feel the Power Supply cooling fan moving air. Either of these could cause your PC to over heat and shut down.
If you need more help come back.Post /
thumbs / testimonial are
welcome!
