Hi Jennyglopez..I do not think your pump is the issue,however you can make this checks.1-Take the filter combination out of the wash cabinet 2-Scoop the water out of the cabinet using a suitable container 3-Press the catch for the non-return valve inwards 4-Lift out the non-return valve and rinse well under running water.5-Remove all foreign objects from then on-return valve and drain pump 6-Carefully replace the non-return valve and secure it with the catch.Ensure that the catch engages correctly.You can also check drain hose &remove any kink in the drainhose.where the drain hose engages under the sink sometime gets clogged.Disengage the pipe & make sure hole in the drainage not clogged.Thanks & goodluck
