Sony VPL-PX41 Multimedia Projector Logo
Posted on Aug 18, 2010
How to reset lamp hours on a sony XGA VPL-PX41
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Nov 04, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2364
Points
Press the following buttons on the control panel in less than five seconds in the standby mode.
RESET, LEFT ARROW, RIGHT ARROW, ENTER
Need to reset lamp hours on sony vpl px31
1,Connect the power cord
2,The On/Standy light is red.
3,Press the following keys on the Remote Commander or on the projector in the following order for less than 5 seconds :Reset,left,right,enter.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: [email protected]
http://www.lampdeng.com
2answers
How I can reset the lamps time?of this model Sony PVLPX41
Make sure that the projector is in standby mode and perform the following:
Press the following keys on the control panel in the following sequence for less than 5 seconds each: RESET, , ENTER
In english: RESET
LEFT ARROW
RIGHT ARROW
ENTER
Please note that this sequence is documented on page 43 of the user manual under changing the lamp.
Dan
I have replaced the lamp in my sony VPL-EX3 projector and it won't turn on how do I reset the lamp hours
DO the following for resetting the lamp hour
1.Connect the power cord.
2.Press the following keys on the Remote Commander in the following order for less than five seconds each: RESET, Left Arrow button, Right Arrow button , ENTER.
ok
Hello, good day. My problem is relationship my sony xga vpl - ex7 not turn on. Only lighting the lamp/cover.
Either lamp is dead/ broken in projector or lamp cover is not fixed properly (its located at bottom side)
Please check lamp and replace it if its broken and make sure lamp cover is fixed back on its location securely after lamp replacement/ checking.
Thanks.
1helpful
How can I reset the lamps hours for SONY DLP Projector , Model: VPL-CX86?
hi,
for resetting lamp hour do the following
press the following keys on the remote in the following order for less than 5 seconds each.
RESET then LEFT ARROW then RIGHT ARROW then ENTER
OK,
I replaced the lamp in SONY VPL-PX41 Projector. The Message "Replace Lamp" won't go away. How to re-set?
hi yes, all you have to do is press, reset, then left arrow, then right arrow, then enter..that should reset the message for you do not press each button in sequence for more than 5 seconds, hope this helps
13helpful
How to reset lamp on sony lcd projector xga vpl-px20
After replacing lamp, connect projector AC power cord and turn the projector in standby mode.
Press following keys on control panel for less then 5 seconds each..
RESET, <==, ==>, ENTER.
That will reset lamp timer in projector.
Thanks.
2answers
Reset Lamp Hours
hi have vpl-es3 i changed the lamp but i have massege replace the lamp
4helpful
Lamp time resetting
HI
Not sure if its in the handbook but you can download a copy from here
http://safemanuals.com/user-guide-instructions-owner-manual/SONY/VPL-CS5-_E
Top Sony Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
