Need to replace my ZISB42DCA should I go with latest Monogram or a comparable Profile or switch to Kitchenaide. We have had a lot of problems with this one but it came with the house.
The defrost drain would be causing the fridge to have water leaking out of it and you will need to also clean the defrosting drain as well or need to replace it.
Try replacing the Water Valve. It is located in the back of the refrigerater, left side. You should see three tubes connected to it. This part fixes the following symptoms - Leaking water, Water dispenser will not dispense water, Ice maker will not make ice and Ice maker won't dispense ice. GE part#WR57X10032. The Water Valve is extreemly easy to replace. Only takes about 15 mins total time to remove, install and confirm. I just replaced mines..my problem went from leaking water to no water was dispensing at all. I have the GE Profile, it uses the same water valve as your GE Monogram. There is a You Tub video that also shows how to replace. Good Luck!
You should be able to see the drain under the coil. Part 804 on this diagram. Your drain tubemay be stopped up with ice at the upper end
because it drains too slow because it's stopped up at the lower end in the
evaporator pan under the unit at the floor. It can get dust and mold in it.
Once you get the ice out at the top a little pressure with a turkey basterwill usually clear it out. Flushing
it out with hot water and clorox may help. Make sure it drains quick enough
to prevent refreezing.
We need to look behind the rear panel in the back of the freezer and need to look at the mother board on both sides. Will need to unplug and begin. Let me know, Sea Breeze
