A dehumidifier works just the way an air conditioner works
but in a reverse manner. If you encounter a problem with your
dehumidifier then it would be repaired the same way you would repair an
air conditioner. As such a dehumidifier does not require much cleaning
apart from changing the filter.
When the filter and coils of the dehumidifier are choked with dirt,
it may not pull out moisture from the air properly. The efficiency of
the dehumidifier gets decreased and the only solution is, to clean it
thoroughly. In order to assist you with the cleaning procedure of a
dehumidifier, following are a few tips:
Also before you start with the work of cleaning the dehumidifier, make sure that it has been unplugged.
Hello friend, that's a great question!
The best way to clean your Frigidaire dehumidifier's coil is by using a brush attachment from your vacuum. I hope this is helpful. -Matt
