Technics SL-DZ1200 CD Player Logo
Posted on Aug 17, 2010
I have had a pair of Technics SLDZ 1200's for 5 years and i can the lens at least twice a month, just yesterday i was gonna do a mix at home and one of the technics is having a sticking type problem.. Its plays the track but it has like skipping parts of the track. Im a DJ and use these decks every friday night at a club i work at..What is the solution to this problem? Do i need to take it to a place, or is there some other type of head cleaner i can by that will fix and stop this problem? I live in houston texas, my name is Jeff White..
Anonymous
Level 1:
New Friend:
  • Contributor 17 Answers
  • Posted on Aug 19, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
17
Questions
0
Helped
6367
Points
42
It sounds like the tracking coil on the laser opu has been damaged during cleaning,,,the lens is suported on two axis . the focus coil moves the len in and out .this is ok because it plays for a bit. then the tracking coil moves the lens to track the disc in sync with the sled movement of the assembley .this is were it is going wrong .. you could look closly at the tracking coil support etc and see if anything obvious .but if not will require new laser op...
Do you have firmware update for Sldz 1200 ? thank you for your help [email protected]
No , I dont have any firmfare update for sldz 1200. as soon as I found it , I"ll contact you. thank you
Nov 16, 2013 • Cell Phones
1helpful
I just purchases a Technics 1200 turntable for $70.00. I have found a problem, at the end of the album, the arm does not auto return, but just stays on the album. Could this be a simple problem,...
First off, Congratulations on such a excellent deal! That's a $500.00 turntable. I know I own a pair and I've been a DJ for 18 years.
Second, the Technics 1200 does not have an auto return. You have to pick up the needle and bring it back manually.
Plug in sldz 1200 no power tried another cord same no power changed out fuse with same amps and volt from radio shack still no power so im stuck help please.
You need to use a ohm meter (you can get one cheap) and find out if the power switch is working. You can also determine with it if the power is getting into the turntable. If the switch is working and power is getting to it, then either the transformer has failed or something is wrong in the power supply section.
I am in need of 2x technics turntable plastic covers. where could i find and how much each?
Hi, We have dust covers in stock for SL1200 and SL1210. If you are in NZ the price for a pair is $195.90 NZD. [email protected]
Technics kn 1200 keyboard
can't find Technics kn 1200.
help me please. Price is not interest.
[email protected]
1helpful
User manual Technics DZ-1200 turntables & Pioneer DJXM600 mixer
I found your manuals below:
Technics:
http://www.givemefile.net/manuals/musical_instruments/technics/sl-dz1200.html
Pioneer:
http://www.nodevice.com/user_manual/pioneer/dj_mixer/djm-600.html
10helpful
2answers
How old is my Technics SL 1210 Mk2
Here's some information for you. Since your unit is a SL1210MK2, it may be harder to determine the age of the unit:
It is possible to tell the year (and the month) when the SL-1200 was manufactured from the serial number on the back or bottom of the turntable. SL-1200 serial numbers are in two different formats, depending on the date of manufacture. It isn't exactly possible to determine the decade in which the SL-1200 in question was manufactured, as the serial number contains only the last digit of the year. If the year digit is 8, the turntable may have been manufactured in 1978, 1988 or 1998. If the year digit is 0, the turntable may have been manufactured in 1980, 1990 or 2000. One rule of thumb is that old-format serial numbers belong to SL-1200s manufactured during the 1970s and 1980s, while new-format serial numbers belong to SL-1200s manufactured during the 1990s and beyond.
Old-format serial number: NHOJF20765 (SL-1200 manufactured 1982)
The first digit shows the year when the SL-1200 was manufactured. These serial numbers contain no indication of the month of manufacture. It should be noted that serial numbers in this format contain no letters following digits.
New-format serial number: GE4FB001154 (SL-1200 manufactured June 2004)
The first digit shows the year when the SL-1200 was manufactured, while the month of manufacture is indicated by the letter following it. Months are coded as letters between A and L inclusive; A indicates January, B indicates February, and so on.
In addition to the above, all the SL-1200MK2s from the 70's and early 80's have a 4 inch diameter plate where the RCA and ground wires enter the chassis in the rubber base of the unit. The later models have a smaller hole through which the wires enter the unit.
TWEAK A/V LAB
www.DJPROLAB.com
Pitch problem
check it.
http://www.repairnyc.com/
These guys are authorized technics service.
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
