It sounds like your defrost heating element may not be working and you should ck the drain line that takes defrosted water to the underside of the fridge. The defrost element is in the back of the fridge where your cooling coils are it will be a a black tube apx 18 inches long with connections on both ends. (some use a glass tube with a element on the inside) IF you take the plastic liner/housing off to get at the cooling cool (called a evaporator coil) and it has a lot of frost and ice on it it is either this element which you can ck with an ohm meter or the defrost timer. The defrost timer is in the fridge side and is under the plastic back or in the center top if your control is there. The timer will have a slot in it that you can turn with a flat blade screwdriver. Turn it slowly until the fan in the fzr turns off andthe compressor and fan kick off go slowly you will hear audible clicks but the defrost mode is just one click wide and it may take a while to go thru all of the clicks be patient. When the fzr fan and compressor kick off wait 2 to 3 minutes and the heating element should get hot and start hissing as water runs across it and the ice will start popping. If this happens the element is fine replace the timer if not replace the element and the little thermal disc (called a defrost limit) that is attached to one end of it make sure to unplug the fridge you will have to cut the wires going to the element and defrost limit when wiring back in just use **** connectors or twist caps and elect tape. good luck hope I helped
