SOURCE: Motorola Razr V3 suddenly stop working - lost outgoing voices ...
open your phone and theres alittle tiny button all the way up at the top push it in with a needle and see if that works
SOURCE: Auto Signature Setup
For the RAZR V3, using AT&T as the carrier, go to the message center, hit the button between the two "soft keys", go to Inbox Setup, MMS Message Setup, then down once, and you can change it from there.
SOURCE: Motorola RAZR V3, Ii hangs when typing SMS.
the firmware needs to be reflash on the phone to correct this issue...take the phone to a mobile service center and have them fix it for you.
SOURCE: Razr screen displays No Service, no outgoing or incoming calls
is not so easy
normaly y say to you buy a new phone
y liked very much motorola
but trust me y repaired to many to lie to you
to fix this problem is to expansiv sory is better if you wil buy anader phone
SOURCE: How to unlock a forgotten password to a locked motrola v3s phone
18*1 - master reset
Should master reset the phone and change code back to default
