Kenmore 62602 Electric Dryer Logo
Posted on Aug 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My plug is a three prung plug and the dryer is a four prung plug what colors goto what on a three prung
Stephanie Miller
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 19, 2015
Stephanie Miller
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
119
Points
My dtyer was a 4 nut I'm trying to connect the 3 wires up. My dryer is an Lg front loader sensor dryer
Anonymous
Level 3:
  • Kenmore Master 43,501 Answers
  • Posted on Sep 12, 2010
Anonymous
Kenmore Master
Level 3:
Answers
43501
Questions
0
Helped
10838095
Points
101584
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Convert 3 wire plug generator to 4 wire plug cord
First verify that the voltage is the same. It sounds like you have a single phase system which is 2 voltage circuits and 1 neutral. The 4th prong will be the ground. To do this properly you will need to get a new 4-wire chord for the generator with a cap that matches the one for your house. On the Generator side, the 4th wire will attach to ground.
Oct 04, 2017 • Dryers
1helpful
Four prong cord three prong outlet
Ok this is how you will wire the three prong to the dryer.
You have 2 wires that are gold/brass in color, those are the hot wires.
You have 1 wire that is crome/silver in color, that is the neutral
On back of fryer where you wire it you put the wires on like this right to left Gold/brass hot, silver/nuetral, then the other hot wire.
On back of dryer you will have screws from right to left this color gold/brass, silver/crome, then gold/brass again.
If you do have a 4 wire cord the extra wire is ground and you screw that to the machine body.
2helpful
3 wire plug Maytag dryer, but a 2 wire prung outlet@120 volts.
your dryer can be wired to run on 120 / i would not do / very costley to run . . this is some times done for display on the sales floor . best is to get gas dryer or have 220 wired to dryer .. if in home . **** ..
1helpful
Plug problem
On a three wire configuration, the ground and the negative are tied together at the center position, using the dryer ground strap. Following is a description of the difference between three and four wire. Hope it helps you.
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom.
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
Sure hope this helps you find a resolution to your delimma! Best wishes.
1helpful
Convert three pin plug to four pin
2helpful
Changing from a 3 prong to a four prong
grasshopper_2.gifWiring in a new power cord for your electric dryer? Upgrading your electric dryer outlet from the old three-prong to the new four-prong outlet? Well, grab hold of those two large lumps at the base of your spinal cord and let's romp through the wild and wacky world of dryer cords and outlets.
tn_3cord_dryer_terminal.jpgtn_4cord_dryer_terminal.jpgThese two pictures illustrate the power wiring on a the terminal of an electric dryer. The one to the left here is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown to the right. These are just just thumbnail pictures that you can click for a larger view. But I'll bet you already figured that out, didn't you?
tn_3prong_dryer_outlet.jpgtn_4prong_dryer_outlet.jpgIf you need to re-wire the outlet, these pictures will explain the anatomy of the three-prong (left) and four-prong (right) outlets. Once again, these pictures are just thumbnails--click 'em for a larger view.
Jul 23, 2009 • Dryers
Stop working
the 4 prong cord should be connected id follows,the white wire to the middle terminal,the red wire on right terminal,the black wire on left termanal,the green wire grounded to cabinet,let me know more,do you have a meter?mike
Apr 19, 2009 • Dryers
Top Kenmore Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
