It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
The first
time that you switch on the 3200 LS-Color, you must pair your mobile phone
with the kit.
1.Enable the
Bluetooth mode on your phone.
2.On the
hands-free kit, scroll through the menus until you come to Settings Pair with
phone and select the relevant option for your phone. A 4-digit PIN code then
appears on screen. Memorize it.
3.Then from
mobile serach the 3200 LS-Color device
Once the
search has finished, "Parrot 3200LS / Parrot 3400LS" is displayed on
your phone.
4.Select the
kit. Your phone prompts you to enter a code: key in the code shown on the
kit screen and confirm on your phone.
5.The kit's
screen displays "Pairing".
6.Once the
data has been exchanged, "pairing successful" appears on the 3200
LS-Color.
Thank You
