Your defrost timer is bad or your heating element. The defrost timer in newer models is inside the fridge side under the plastic cover in the back or if you have a light and dial themostat dial in the top centre its there. The timer will be black with a shaft in the center that a flatblade screw driver can turn. Turn it slowly one click at a time until the fan and compressor kick off. (the fan in the fzr will kick off also) You can hear audible clicks but go slow the defrost mode is just one click of the dial and it may take you a few minutes to hit the spot. When the fan and compressor stops wait about 3 minutes and listen to the freezer you should hear hissing and popping ice sounds if you dont you need to defrost the freezer and take the back off so you can see the cooling coils you may have to defrost it even more once the coils is exsposed. You will see a black heating element (or a glass one with an element inside rare) this element will be attached to the cooling coil and on one end of it will be a nikle size disc this is the defrost limit it keeps the heating element from getting to hot for to long. If the element is bad it will usually have a spot in it blown out and burnt. You can ck the element with an ohm/volt meter these can be picked up at any hardware store for 5 to 15 dollars. It will come with directions on how to use it. But either your defrost timer,element,or thermal limit is out. If you have any trouble let me know and I will walk you thru it. good luck and respect the electricity and unplug the fridge before testing parts.
Check
out these tips...they can help you figure out what is going wrong
with your refrigerator and why it is not cooling
Refrigerator
not Cooling
or Fridge not Cooling
How to Defrost Refrigerator Defrost
Timer Problem
Water
Running in refrigerator
from Freezer
Refrigerator
or Freezer not Cooling or Getting Cold
heatman101
