Security key in side the router. To get the key you need to access the routers web interface. Please follow the steps below on a wired pc. A pc which is directly connected with the netgear router using an Ethernet cable.
1. Open internet explorer and in the address box type http://192.168.0.1 and press enter. It should ask you a user name and password. User name is admin and password is the word password. click on login or ok.
If you don’t get user name and password window with http://192.168.0.1 and try http://192.168.1.1 or http://routerlogin.net
2. Click on wireless settings on the left hand side.
3. Under the security section if the security is wep then note down the key one and this is the security key you need.
If the security is something else then you wont be able to see the security key it will ******. In this i'll suggest you to change the security key to wep, encryption should be 64 bit and authentication type should be open. In the security key one box you need to type in the security key, The lenght of the key should be 10, you can only use a-f and 0-9. For example 123abc567f. and save the settings.
Try connecting on the wireless pc.
Note: if you change the security key then you need to connect all the wireless devices with the new key.
Hope this helps you!
Rashish.
SOURCE: have lost/can't remember the security code to wirelessly connect to my netgear DG 834G
Paul.
Can you connect to the router via ethernet?
If so assuming you havent changed the routers address connecting to 192.168.0.1 from your web browser should get you into your routers admin page.
Once you have entered the user name and password click the Wireless link from teh main menu where you will be able to see the relevent key and or change it if required.
If you need the manuals you can download from here.
http://kbserver.netgear.com/products/DG834G.asp
Regards
Nick
SOURCE: NETGEAR WGR614v7 Network Security key
Hi, you need to connect to the routers admin pages to configure the wireless settings and security. Check out this page:-
http://kbserver.netgear.com/kb_web_files/n101676.asp
When you get to step 6, click the WPA-PSK security setting and it will give you a box to type in a password of your choice, make it memorable but difficult to guess, so a mixture of numbers and letters. I think its a min of 8 characters.
Hope this helps..
SOURCE: I can't connect to my wireless netgear wndr3300 to XP
It seems that the wireless adapter on XP does not support WPA2 Security. Please enable WPA-PSK on the router and check if you are able to connect to the wireless network on the XP computer.
ENABLE WPA SECURITY
1. Open the browser (Internet Explorer, Mozilla Firefox or Safari) on a computer connected to the router.
2. Access the router, usually with http://192.168.1.1 or http://www.routerlogin.com.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
4. Click on Wireless Settings (under Setup) from the left menu.
5. Select security options as WPA-PSK. Enter a Password in the passphrase box. Apply the settings.
Configure XP computer:
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply.
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab.
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight thee SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
SOURCE: I have wireless network Netgear / lost security key
Log into your router ( default log in details can be found by googling your make) if you have changed the log in details, you may need to reset the router to factory default ( again, google this for a how to)
Go to wireless settings and then security ( or the other way around depending on your model) and your key will be there
