You can download the user manual for this unit from this link.
http://www.retrevo.com/support/Acer-A150-Laptops-manual/id/21284dj687/t/2/
Using this link you get all users manuals http://support.acer-euro.com/documents/manuals.html
SOURCE: Key bord & Mouse Paid hang Acer Aspire 1642ZWLMi PC
Try to remove your battery first, battery can cause the mouse and keyboard freeze.
about the shut down problem, is it take long time to shut down, if it is, you should check your harddrive.
SOURCE: My acer 3100 does not recognize internal usb
Go into device manager and Un-install them and let the computer Re-install them.
SOURCE: HOW TO ACTIVATE THE BLUETOOTH IN ACER ASPIRE 4730Z
make sure the drivers for the bluetooth are installed, then switch it on.
http://support.acer-euro.com/drivers/downloads.html
if it doesn't turn on make sure you have all the drivers and utility programs installed from the above acer page, then it should turn on.
SOURCE: for acer aspire 4730z note book usin vista
All Drivers for your acer aspire 4730z ia available at http://www.downloadya.com/files.php?cat=132
SOURCE: can not boot up my acer aspire one note book?
Thank you ANdrew!
It really helps me today. I have the same problem. I am almost dying. Then I download the bios flash (new version 3310 ONLY for 150 or 110 aspire one, see the instruction on acer website). I changed the name and did everything as what Andrew said.
It really works. Then the Winxp starts, there still 3 programms running there!
Hope this trick can also help others in emergency.
I wonder this flash ation is just like the function of a RESET button.
CAUTION: flah bios may cause when you use a wrong version!
