SOURCE: Ignitors are igniting on their own
they are not lighting they are sparking on there own right? No actual flame? if they are sparking on there own you need a new spark module.
SOURCE: Have a four burner gas GE Profile cooktop. How do
The igniter module is working fine. One of the switches (which are on each valve shaft) is stuck or shorted out. Pull a wire off each one at a time to determine which one is bad. Careful! 120 volts to each wire. Also, this can happen after you spill water into the valve area, if that sounds right, let it dry out.
SOURCE: why is ON light glowing with knobs on off
That is to tell you that your Infinity Switches are faulty and no good.
So whatever one is lit, change it
SOURCE: One of my cooktop knobs won't activate the ignitor
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
SOURCE: need to clean contacts on control knobs under
Sorry to read about your problem, I hope this helps you out.
their is no cleaning of contacts, they are sealed units..have to replace the switch,
you have to remove the entire range from the counter top..will take 2 people
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
