Fisher and Paykel Active Smart® E522BR Stainless Steel Bottom Freezer Refrigerator Logo
Posted on Aug 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The alarm beep which tells you to close refrigerator or freezer door now beeps even after either door has been closed. It beeps three times at approx twenty second intervals, then beeps continuously for about five minutes. Then only way to stop this is to press the button inside refigerator at back (near top), and only during the continual beeping. When I open fridge to do so, I notice that interior light is off. The light must reset after a while because it later comes back on. The beeping also happens randomly when fridge has been closed for hours. Usually it stays in the 'five sets of three beeps then contnuous beeping' cycle, but sometimes it stops before continuous beeping. In any case, it's incredibly annoying. The fridge is in a rental apartment and getting the landlord to attend to this has been impossible to if there is an easy solution I would so appreciate it. Thanks!
Anonymous
Level 3:
Genius:
  • Master 1,622 Answers
  • Posted on Aug 15, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1622
Questions
Helped
391876
Points
4742
Sounds like you have a bad door switch. Depending on the age of the fridge, it might still be under warranty. If it's not, then you might be able to access the door switch yourself and pull it out & replace it.
Good luck......
2answers
GE refrigerator constant irregular beeping
It looked like your model does NOT have an external ice/water control panel which has caused beeping problems on some models.
For your model I would try the following....
Door Alarm
The main cause of a beeping GE unit is an open refrigerator door. Some models are equipped with an internal door alarm, which trips when the door remains open for 3 minutes or longer.
One way to check this .... put your smartphone in the refrigerator on video mode and close the door. The light should go off with the door shut. If the video shows that the light stayed on when the door was closed ... then it reinforces that something is wrong with the switch/alarm. Repeat video for the freezer.
Door Seal
If beeping persists after the freezer or refrigerator door is closed, the door seals may be blocked or so dirty that the internal door alarm is tripped. The seals can be cleaned with a soft cloth and warm, soapy water. Also, an item inside the refrigerator may be preventing the door from fully closing.
Cooling System
Reactivating the refrigerator's cooling system includes a beeping noise. When the refrigerator is off, the "Off/Off" light appears on the door display. When the "Adjust Freezer" and "Energy Saver" buttons are held down for approximately 3 seconds at the same time the beep sounds and the "Off/Off" indicator disappears. Hold the "Ice Off" and "Freezer" buttons to activate the cooling system inside of the fresh food compartment. A beep signals the system is activated. The beeping should stop after the cooling system turns on. If it fails to stop, try unplugging the power cord to reset the connection.
Power
The GE's internal door alarm can get stuck. Try unplugging the refrigerator for about 10 seconds and then plug it back in. If the beeping continues, the internal door alarm might be broken or defective. Contact the manufacturer or a technician for further assistance. One way to check this .... put your smartphone in the refrigerator on video and close the door. The light should go off with the door shut. If the video shows that the light stayed on when the door was closed ... then it reinforces that something is wrong with the switch/alarm.
Good luck on your troubleshooting!
E240B Fridge Freezer door open alarm goes even when door closed.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Fisher paykel freezer it only has audible alarms and i dont know what its trying to tell me
Looking for specific answers? Provide more details.
  1. Model number of freezer will help.
  2. Does alarm beep when door is closed?
  3. Does alarm beep when door is open?
  4. How many beeps? The amount of beeps will indicate the fault code. From there, more information can be provided.
Frigidaire refrigerator beeps every 20 seconds or so. three beeps.
try opening the door.leave it open.unplug the fridge for at least 5 minutes, no less,with the door still open.after that,plug it back in.wait for it to beep.then close the door.
this would reset the door alarm,which beepes when the door isn't properly closed.
also you should wait 24 hours between changing the temperature or it can mess up your fridge.!
Freezer bleeps as if door open. Temp goes down on its own
Kenmore freezer door alarm beeps but door is closed ...
www.shopyourway.com > Manage My Life > Questions
Every once in a while, the door ajar light goes on and the alarm beeps and will not ... Ifthe door is closed good and the door alarm is sounding, it will indicate the ...
How to fix constant refrigerator door alarm beeping? - Shop ...
The doors aren't open and we have checked the air flow vents and made sure ... We have to turn the alarm off to get it to stop beeping but I more concerned about ... If the fresh food section lights are working, meaning you can get the lights to go ... Thefreezer fan motor would need to be checked to make sure there motor is ...
Why does my Hotpoint ff187e frost free fridge freezer lights flash and the alarm sound even after reseting them as per manual. rest them ok for a while but then restart what's the problem?
How do you get door ajar alarm to stop beeping on upright frigidaire freezer when door is closed
Even though my door was closing fine it was beeping and saying "door ajar", so I first removed the switch. But that wasn't faulty and even with it out of the equation the beeping was there. I fiddled around some more but rather than rip everything apart, I popped out the electronics on the front and twisted off the little round black beeper in the circuit board.
Now I don't have a working door alarm. But otherwise: problem solved! ;)
I have a Frigidaire freezer , M# GLFU1767FW4 S# WB70936901. The computer keeps on beeping, even when the door is closed, the temperature is fine. I already changed the computer and the door...
Hi, the door switch might have had liquid poured on it freezing it, or the switch itself is bad.
Unplug your refrigerator from the ac outlet, and 0pen the door for approx. 5 minutes. Then plug it again, after you hear the beeping close the door.
Beeping from refrigerator about once a minute.
If this is listed under the right model, then the only thing it could be is some models have a
door alarm,that will beep if the door is not closed. You could check and clean the gasket.
Or it the switch that tells the fridg that the door is closed. Check if there is a top door adjustment to bring the door closer to the fridge where the door hinge is. This might apply or push on the switch more.
Top Fisher and Paykel Refrigerators Experts
Grand Canyon Tech
Grand Canyon Tech
NOEL
NOEL
john h
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
