Question about Frigidaire FEF336BC Electric Kitchen Range
Electric stove wont sef clean gives a f9 err - Frigidaire FEF336BC Electric Kitchen Range
  • 15,935 Answers
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Oct 01, 2010
6ya staff
SOURCE:
On my new stove i got a F9 code what can i do to get my stove to work
Possibly incorrectly wired. Often these codes are make specific.
F9 or F9 E0 - Whirlpool Home Appliances - Whirlpool® product help
producthelp.whirlpool.com/...Guides/...Ranges/...Code%2C...Code.../F9_or_F9_E0
Apr 22, 2017 - Reset power to the product: This code will most often indicate that the appliance is wired incorrectly at the home electrical supply, or at the hard wire connection. If your oven was installed recently (within approximately 3 months), contact a qualified electrician to verify the electrical supply. During a power ...
What does the F9 error code mean on my Kenmore range Model 790 ...
https://www.shopyourway.com/questions/1074065 Apr 6, 2010 - Door locked started blinking, door never locked,..pressed clear button caused "dr" code, pressed clear again and "f9" and beeping occurred. ... This was extraordinarily helpful...we got this oven from my mom in law when our old one died and she bought a new one, we knew nothing about it but thanks to ... How do I get rid of F9 error code on range?
18 Dec 2011
Why does my Kenmore oven display the F9 error code ...
1 answer
29 Oct 2009
How do I reset an F9 on Frigidaire oven?
1 answer
26 Oct 2009
What does the error code F9 mean on my Maytag ...
1 answer
11 May 2008
More results from www.shopyourway.com
going to clean the oven but got a f9 error had to reset it for it to work ...
? 1:49
https://www.youtube.com/watch?v=cgGKxTxxf4E May 17, 2016 - Uploaded by mike webb
going to clean the oven but got a f9 error had to reset it for it to work mike webb po box 408 stryker ohio 43557.
F9 Error Code - Whirlpool , KitchenAid & Kenmore Range - Repair ...
? 1:01
https://www.youtube.com/watch?v=MXMDjZRNDnw Oct 31, 2014 - Uploaded by ApplianceVideo.com
Visit us at http://www.appliancevideo.com Do-it-yourself diagnostic and repair videos brought to you by ...
stove got F9 code Google Search
Mar 18, 2018 | Kitchen Ranges
How to get the F9 err off when i press the button clean for my oven
The F9 code indicates a problem with the door lock. (Since the oven must lock the door for a cleaning cycle, this will be a "fatal" error for the cleaning cycle.) There are a few possibilities. Open the oven door and look for a L-shaped piece of metal on the top of the oven frame. Check that this lock part is angled to go straight up (12 on an analog clock). If it is rotated slightly, it won't fit properly during the lock cycle.
Clean the latch and wiggle it to check if it will move freely. If these steps don't fix the problem, you need to check the door latch motor and switches. You will need to take off the back panel of the oven to find the motor. Check for loose wires or damaged/loose switches.
If the motor assembly and switches are good, then the central control (clock) probably needs to be replaced.
I hope this helps.
(most self-cleaning ovens will eventually have a problem with the lock assembly.)
Sep 24, 2013 | Frigidaire Stove/Oven/Range Cooktop -...
It was smoking so i turned sef clean off on the f9 what does that mean
F9 Oven door lock failure Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch.
Sep 17, 2010 | Kitchen Ranges
I put my kenmore oven on to clean.I PRESS CLEAN AND THAN START.THE DOOR LOCKED AND THE CLEAN LIGHT CAME ON.AFEW SECOND LATER I HEARD BEEP BEEP AND ERR-F9.GOT MY BOOK OUT AND FOUND NO ANSWER.SO I CALL...
Aug 16, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Put oven on self cleaning and all it does now is beep and reads error f9. wont go back to where i can use stove top or oven
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#@%@#%%@
Mar 02, 2010 | Frigidaire PLEF398AC Electric Kitchen...
My Electric Frigidaire Convection Oven just locked it's own door! I heard a continual beep..then "Err" "F9" flashed, then beeping stopped and the illuminated "padlock" symbol lit up and the door locked...
I have a similar problem with my electric Frigidaire convection oven, which flashes ERR F9 and beeps after finishing a cleaning cycle; if you haven't had to have it repaired professionally by now you might try cutting the circuit breaker to the oven for a few seconds and then turning it back on. My oven takes a few minutes to reset, after the circuit is turned back on, but then will unlock the door and let me reset the clock and continue cooking as normal. . . until the next time I set the clean cycle.
FW
Seattle WA
Dec 15, 2008 | Frigidaire 30" Self-Cleaning Slide-In...
Jenn-air shut off while cooking giving f9 code
code F9 keeps flashing when I attempt to turn on my oven. What does this mean?
Sep 03, 2008 | Jenn-Air JES9800A Electric Kitchen Range
Frigidaire FEF336BC Electric Kitchen Range Logo
76 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
