If you often change your Windows password or your memory isn't good, it is normal that you forget the password. To help you remember, or on the lowest to help you be in control and know your password, why do not you obtain a software program plan that will reset the password for you? The software program plan is capable of resetting and positively removing the more mature password in purchase for you personally for getting in a location to available your operator account. Why do not you consider a glance at this software program program? Please visit: http://www.passwordseeker.com/howtouse.html
If you lost windows password, you can go into safe mode (F8 when booting up) to recover windows password, but you forgot administrator password, that way doesn't work. you must use software to recover administrator password. This method is very easy. You can go to this site http://www.reset-windows-password.com/how-to-reset-windows-password.html
If you have a password on your windows, you can remove it with windows password reset tool. For removing Windows 7 password, I recommend windows password reset 9.0. last week, I downloaded it and used it to remove the lost password within only few minutes. Furthermore, the powerful tool didn't cause a little data lose.
Maybe you didn't set an administrator password yet. If you are in windows XP, just try to leave the administrator password blank. if you are using windows 7, maybe you forgot windows 7 administrator password you set before.
In this occasion, you'd better reset windows administrator password with a third-party program like Windows Login Recovery, download it and install it in an accessible computer, and burn a bootable password reset CD/DVD or USB, then you can get windows 7 administrator password recovery in several minutes.
There are many Windows password reset tools,but I haven't personally tested them. Windows Password Recovery is awidely spread edition though...
Once reboot the computer with CD/DVD/USB, remove the lost or forgotten passwordand then log in to your computer without any password.
A Windows Password Reset Disk could do all the job for you, it can reset your lost Windows password safely and quickly without login, you can use the tool Windows Password Breaker to help you create a Windows password reset disk, then reset your password.
SOURCE: i created a user name and password on my asus lap
Software to reset Windows Administrator password is available from several vendors. Here's a couple..
http://www.spotmau.com/products/package/how_to_reset_administrator_password.html
http://www.windowspasswordsrecovery.com/getting_started/index.htm
A review of the top 7 free Windows Password Recovery Tools is available at the following link...
http://pcsupport.about.com/od/toolsofthetrade/tp/passrecovery.htm
Asus Eee PCs run on the Windows XP SP2 operating system. Accounts in Windows XP SP2 can easily be password-protected, but the same password can just as easily be forgotten.
At moments like this, you'll wish you had chosen a password that is both secure and easy to remember, or kept a record of it in a private place.
The quickest way to get back on the computer is to seek out someone with an administrator account on the computer.
Press "Control" + "Alt" + "Delete" at the same time on the locked screen.
Select "Switch User."
Remember, only an administrator account registered on this computer can unlock the computer.
Type in "administrator" in the user name box.
Type the password that corresponds to the administrator user name in the password box .
Click "OK." The Asus Eee PC is unlocked.
Hope this helps
1. download Spower Windows Password Reset and use it to create a CD/DVD or USB password recovery boot disk.
2. Boot you laptop from password recovery boot disk and follow the wizard to reset recover the forgotten password.
[B] Spower Windows Password Reset[/B]
You can get Spower Windows Password Reset fromhttp://www.windowspasswordsreset.com/
