Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
Posted on Aug 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a stihl km 55 r strimmer but i need to know the 2 stroke mix ratio
Anonymous
Level 1:
New Friend:
  • Contributor 26 Answers
  • Posted on Oct 22, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
26
Questions
0
Helped
14769
Points
40
50:1 with stihl oil.. for ALL stihl products.. use mid grade gas too
Anonymous
Level 2:
New Friend:
  • Expert 50 Answers
  • Posted on Aug 14, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
50
Questions
0
Helped
29915
Points
102
hvend
Level 1:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 65 Answers
  • Posted on Aug 03, 2016
hvend
Contributor
Level 1:
Cheetah:
Answers
65
Questions
0
Helped
57430
Points
91
Yes, 50 to 1 with the Stihl Full Synthetic 2 cycle oil......or the Echo Syn Blend oil . ALWAYS use NON ethanol gas, and you will be much better off, as the ethanol will foul your small passages in carb .
1helpful
JCB M25 strimmer, bought second hand does anyone know the fuel mix ratio please ?
TO MIX THE FUELSee Figure 3.? The product is powered by a 2-stroke engine and requires pre-mixing petrol with2-stroke oil. Pre-mix unleaded petrol and 2-stroke engine oil in a clean containerapproved for petrol.? The engine is certified to operate on unleaded petrol intended for automotive usewith an octane rating of 91 ([R+M]/2) or higher.? Do not use any type of pre-mixed petrol/oil from fuel service stations, such asthe pre-mixed petrol/oil intended for use in mopeds, motorcycles, etc. Do not useautomotive oil or 2-stroke outboard oil.? Use only synthetic 2-stroke oil.? Mix 2% of synthetic 2-stroke oil into the petrol. This is a 50:1 ratio
Feb 12, 2019 • Garden
Ratio for 2 stroke mi
if you are asking the oil /fuel ratio for a 2 stroke small engine. not being told the size, make or model makes an answer impossible
however Stihl have a special 2 stroke oil that is mixed at the ratio of 50:1 and that will cover all ratios from 20:1 to 50:1
Saves having different cans for all of the engines that can be a workshop
Mixed correctly it works well and if you want just the one fuel can that includes 4 stroke engines
the 50:1 ratio makes for good upper cylinder lubricant in those engines as well and you will not even see it smoke
Apr 21, 2018 • Garden
1helpful
Is the JCB M25 strimmer petrol only or 2 stroke please. can't find manual. Many thanks, Margaret
it is a petrol engine and the carby listed indicates that it is a 2 stroke
the oil /fuel mix ratio is 50:1 with a fuel octane rating of 91 ( do not use e-mix fuels ) recommended oil from the manufacturer specifications is a synthetic 2 stroke oil
Brand of manufactured oil optional
Jul 30, 2017 • Garden
What is the gas to oil ratio for a Homelite backpack blower model # UT08111A
50:1
consider using stihl 50:1 oil as it is made to run in any 2 stroke engine at any ratio that way you only need one fuel tank correctly mixed for all 2 stroke operations
2answers
What is the petrol to oil ratio for this engine
http://www.csgnetwork.com/oilfuelcalc.html
In the Mix
All STIHL gasoline-powered equipment uses a 50:1 gasoline/oil mixture. The chart below can help you figure out the correct measurements to use. For high-performance fuel that requires no mixing, choose STIHL MotoMix® premixed fuel.
Jul 20, 2015 • Garden
2answers
What is the fuel oil ratio per litre for a husqvarna 535rxt strimmer
If it is 2 stroke, take petrol /fuel and mix it with preferably synthetic2 stroke oil.
Ratio is usually 10L petrol mixed with 200 ml or 2 stroke oil, that is the best result, used it on my chainsaw, strimmer, moped, working for years without a glitch.
Two stroke fuel mix for 250 ls grass strimmer
I run a 40:1 ratio in all my 2-stroke equipment. I use my equipment VERY HEAVY every day, and it consists of Stihl, poulon, John Deere, etc... Just don't go over 50:1, or under 32:1 and you should be fine!
Sep 28, 2011 • Garden
14helpful
What is the 2 stroke petrol mix for a garden strimmer, Ryobi 25cc PLT 2543 please?
hi there keithprobert
the ratio to use if using top quality 2 stroke oil is 50:1 that is 20 mills of 2 stroke oil per 1.0 litre of petrol that you mix.
but if not using top quality 2 stroke oil use ratio 25:1 that is 40 mills of 2stroke oil per 1.0 litre of petrol that you mix.
cheers pauly46
dont forget the thumbs rating
Jun 02, 2011 • Garden
2helpful
3answers
What fuel does my strimmer require - McCulloch 240
Most trimmers require a mix of regular unleaded fuel and two cycle oil...the ratio is usually 50:1...you can purchase the oil in convienient packages that allow you to add the whole package to 1 gallon of fuel to obtain the proper mix
10helpful
3answers
Need to know gas to oil ratio jonsered 535 chainsaw
50:1 is the mixture for the Jonsered 535. I bought mine new around 1991 and it's been a great saw.
Apr 04, 2009 • Garden
Top Ryobi Garden Experts
Jay Finke
Jay Finke
john h
Steve Sweetleaf
Steve Sweetleaf
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
