I am trying to get my email to work and I guess that my radio has been turned off. The problem is that I can't figure out how to turn the dumb thing back on. HELP!
Actually the above solution is wrong.
to turn the wireless radio back on
1. go to "manage connections"
2. check the box that says "mobile connection"
This just happened to me and now my wireless radio is back on. Good luck!
If the radio has been turned off, there should be an icon saying 'turn wireless on'.
typically it will be towards the bottom of the handheld.
if that doesnt work, try a powercycle. remove the battery and reinstert it. try going into options>mobile network> network selection (change from automatic to manual) and select your network....
Problem:blackberry pearl enable radiohow to turn the radio on blackberry pearlResolution:Scroll Down and select turn wireless on
To turn off Select it again and select Turn Wireless Off
Actually all of those solutions work at times but on mine when i went to make a call it asked me to turn it on and i just clicked it and it worked
I just got frustrated and took the battery out then turned it back on..problem solved!
I had the same issue for the first time this morning....and I had my phone in my pocket last night...all the obvious resolutions didn't work because all my "info guts" were blank...security etc. I removed the battery for a couple of minutes and put it back in and it restored all info and connection status on its own...
If you go into your network store, I'm sure they would be able to help you.
Try the link www.blackberry.com/RimBlackberryPearl8100
For find a best solution.
Please Rate me if this information helpful for u.
SOURCE: Need to "turn on radio"
Menu key is to left of trackball, select with trackball, scroll to manage connections icon, select with trackball, will give you an option to turn on phone.
How do I turn the phone back on? It says the radio is off so I can't send any text messages or make calls????
how do i turn the radio back on?
blckberry
i just got a blackberry rim and its saying that the radio cant turn on
My radio absolutely will not stay on. I turn it back on and in no more than two minutes it is already off again. Theres gotta be someone else that's had this happen. HELP!!!
the raido wont turn on
i lost the ball to scroll with on my blackberry pearl
and the radio turned off
is there a way i can turn it back on?
Solution link . . . . http://www.IMBlackBerryPearl8100.com,
