Question about Whirlpool GEQ8811L Electric Dryer
Unit begins to work correctly and after it runs a little and gets hot it cuts off. After 5 or 10 minutes it begins to run again. Does this often. Any ideas?
  • Whirlpool Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
6ya staff
SOURCE:
I have a proform 550e, starts up fine runs well for a few minutes, then belt stops. Motor keeps running. I step off the belt, belt starts to run again.
check adjust belt tension
may have to clean under belt area as there could be a build up that is stopping the free movement of the belt as it gets hot
Jul 29, 2018 | Proform Exercise & Fitness
Why does the unit keep on switching off after running for 2 minutes
Do not know what brand or model your aircon unit is? Sounds as if the temperature you want your unit to run at has already been reached. You need to follow these steps:
- select the temperature you want
- select the icicle icon for cool or thermometer icon for hot.
- select "auto" for your unit to cut in, or to cut off to keep your desired room temp.
For example - hot day 26 degrees and you want the temp in the room to drop to 19 degrees - the unit will shut off once it reaches 19 degrees if it is set to "Auto". Hope this gives you some clues to get it working. Please tick my this helped me box if my tips work. Good luck Gerri.
Nov 27, 2015 | Heating & Cooling
It will crank and run good for 10 minutes and shut off. Once it shuts off when you restart it, it will only run for a couple of minutes and shut off again ?
I would start by getting a can of carburetor cleaner and have it 'at the ready' and try the 'start, run stall, start run stall' operation again. Only THIS time, once the engine begins to stall, give it a couple of quick shots of the cleaner into the air filter to see if it stays running on the cleaner.
If it does, then it's still a fuel problem. If it doesn't, then it probably an ignition problem. I would be sort of leaning towards the ignition coil getting weak. The reason I'm saying that is your statement about it running (I'm assuming cold start) for at first, 10 minutes then it stalls. Start it again and it runs for a couple of minutes and stalls again.
This could possibly be from the coil getting warm/hot and not producing the needed spark. After a 10 minute run it simply gets too hot and stalls the engine. After the next restart, the coil is already warm from the engine and so it don't take as long for the coil to get hot and stall the engine again.
Hope this makes sense and helps you out.
Apr 25, 2015 | Honda Gx340 Gas Engine 11hp Motor Pressure...
I have a 2004 polaris sportsman 500 when it gets hot it cuts off and back fires
Does the cooling fan ever run when the engine is hot? If not, you may have a problem with the fan thermostat.
For the record, spray carburetor cleaner does no good if it's sprayed on the outside of the carburetor with the engine running. That's not what it's for.
Jul 29, 2014 | Polaris 2004 Sportsman 500 H.O
Sime super 80.. Heating and hot water at the same time?
going off on a safety possible high temp unit needs service such a nozzle filter if oil or thermocouple if gas
Jun 16, 2017 | Water Heaters
Chainsaw runs 1 minute then suddenly stops. Won't restart until cooled down. Cleaned carb & fuel pick-up also changed plug.
A number of reasons for this, poor quaility fuel causing vapour lock, over heating due to starter cover vents blocked,cylinder fins clogged, running too lean on the carb mixture settings, fuel tank breather clogged ( slacken off fuel cap when it starts to die, if it picks up again, replace tank breather, or ignition unit breaking down when hot ( only cure is to replace the unit )
Oct 11, 2011 | Garden
1996 cavalier hesitates randomly then will work fine again???
sounds more like the coil packs are shorting out when they get hot.
Nov 29, 2009 | 1996 Chevrolet Cavalier
Our Whirlpool dryer runs, then cuts out. After a
Sounds as if your motor is defective. It has an internal thermal switch which cuts the motor off before it gets too hot. After it cools, the switch makes up and the unit is able to run again.
Aug 01, 2009 | Dryers
Power interuptiions
The unit is most likely getting too hot. Check your speaker cables for frayed wires that may be touching each other. The amp will continue to work, but work much harder into a lower impedence load. Over time this will damage the amp. If the cables are OK, try running the amp with the speaker wires disconnected. If the unit still behaves the same way, there is a problem internally with the output section that should be corrected ASAP.
Dan
Mar 31, 2008 | Yamaha HTR-5990 Receiver
Whirlpool GEQ8811L Electric Dryer Logo
48 people viewed this question
Top Whirlpool Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Ned Halaweh
Ned Halaweh
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
