Dr,ser.. iwon..ms-7507..msi 1996..vga driver... plese
Hello the drivers can be downloaded here:
http://www.msi.com/product/mb/K9N6SGM-V---K9N6PGM-FI---K9N6PGM-F.html#/?div=Driver&os=All
Please select your windows system.
Next click on the driver you need for download.
The file is compressed to the zip format, so you need to unzip the file before you install the driver.
I recommend to install the chipset driver first and reboot your machine.
There are many models of this mainboard, so the drivers can be different.
Try also to enter the bios, by pressing the del button when the machine boots up.
In the bios you can tell what MS XXXX number the mainboard has.
The MS XXXX number can be used here:
http://dk.msi.com/service/download/
In seach for the drivers, if i am incorrect.
Just enter the number in the seach field, and press go.
The mainboard number is sometimes placed on a sticker just below the power supply.
Try also google seach when you find the ms 4 digit number.
N1996 does not help in the seach field.
This type of mainboard has been used in the brand: HP, Hewlett packhard and some others.
So a seach on the manufactures site of the pc is also an option.
Best of luck
A lot of people were looking for N1996 board drivers, thinking that
N1996 is the model number for their MSI products, such as MSI
motherboards, optical drives, VGA cards and etc.
Well, that is not the model number because it is not possible that alot of products sharing the same model number, right?
Therefore, the easier way is to use DriverScanner which will help you identify your MSI model information correctly and then locate the most recent driver for it.
Then some one on forums mistakenly saying that N1996 is MSI FCC
identifier printed on all MSI boards/optical drives/VGA cards, which is
NOT TRUE as well. To know what N1996 means to your MSI products, see
below for the proof:
According to MSI official website,
A C-Tick mark (see above) may also appear on MSI products that are
required to comply with Australian electromagnetic compatibility
requirements and radio-communications standards.
It signifies that the product may be legally sold in Australia. Now it
requires EMC compliance must be marked with the C-tick logo and ACA
supplier code number.ACA supplier code for MSI is N1996. The
supplier (in this case is MSI) is responsible for holding a Compliance
Folder that contains compliant test reports and a Declaration of
Conformity.
This is more about ACA supplier code. According to ACMA (Australian
Communications and Media Authority), Supplier Code Number means the
number issued to a person by ACA or ACMA upon application for
registration to use the compliance marks (A-Tick or C-Tick).
So now you know that N1996 is the FCC identifier code for MSI products.
There is no way to identify the correct model number by just referring
to N1996 alone. To find the exact MSI drivers, you need to find out the
correct MSI model numbers, for example here are few of the correct MSI
model numbers/codes, hope you can see the pattern here:
Alternatively, you can try the Free Driver Scanner.
SOURCE: i need msi n1996 mother board drivers
I need motherboead driver for " ms 7336 ver 1.0 " damn i cant find it lol
