Had my c330 for about a year (since 12/06) and had no problems. Last fall we started having trouble acquiring satellites...but it would usually pick them up after 5 minutes or so. Now we can't pick up a signal at all...neither in the car nor outside. Battery is strong. Any help would be greatly appreciated.
Previous post correct. Garmin suggests software update, purchase of new maps or hard reset.
Neither the free nor $70 map update fixed my acquiring satellite problem.
The hard reset work (turn power off, push and hold lower right corner of screen, turn power on. this purges your favorite locations). But it only found satellite for that one session and I had to keep resetting the unit.
But I noticed that, during the reset, my unit was "Locating satellite" rather than "Acquiring satellite". I found that there was a simple way to force the unit to Locate rater than Acquire.
After the unit fails to Acquire satellites, it asks "Are you indoors" and "Are you still in STATE". If you answer "NO" to both, the unit attempts to Locate the satellite (without purging favorites) and has been working for me for the last month or so.
I went to the Garmin site and clicked on Support and Frequently asked questions. I found the problem " problem acquiring satellite". Garmin offered two solutions. The first solution is the free updating of the software. There is an updating tool that you download and it looks for all software updates for your particular model. The tool downloaded a software update (software updates are no cost) and the Garmin C330 is now acquiring the satellite. Either my Garmin needed a software update or else my software somehow got corrupted and the fresh software fixed the problem. Either way, this is an inexpensive way to fix this problem.
Garmin nuvi
will not acquire satellites
I am having the same problem acquiring satellites. I have had the unit for about a year
I am having the same problem, had my unit after about 2 years
I updated the firmware (available from the garmin website)
http://www8.garmin.com/support/download_...
...and now it works fine.
does not connect satelite..
I have had the Garmin C330 for 18 months. Two months ago it took 20 minutes to find the satellite. Now it no longer finds the satellite. My battery is fully charged. The signal strenth indicator has no bars. I am in a location that normally acquires a satellite. Garmin wants $70 to update my maps. I am not sure this will help. Any suggestions?
Murray Berkowitz
My e-mail address is [email protected]
