Your problem may be that you need to select the "AV" input on the HDTV. Samsung HDTVs of late combine the composite video with the green input component video. To use the yellow composite video in the green input port you have to select the proper AV input on the TV which tells the TV to go composite video (yellow) instead of component video (green). Try this, it may work.
