SOURCE: We have a Frigidaire 70
I had the same problem with the LAD 704 DUL......I tilted the unit back just a little bit. The water is now flowing through the hose and into my drain....
SOURCE: I have a drain hose hooked to the dehumidifier,
The bucket should not fill up. Did you remember to take/knock the plug out of the drain hole?
SOURCE: Problem with draining water through hose
I raised mine up on a platform about 6 inches, and now mine works fine. Don't know why this is necessary, but atleast it works now.
SOURCE: Hose line is no longer draining the unit, bucket fills instead
Sounds like the connector hoae came off inside the machine . Look up inside the machine where the bucket would go and you should see where the hose attaches to the condensate drain . It might have pulled off .
