Abit NF8-V Motherboard Logo
Posted on Aug 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an Abit NF8 series motherboard and am using a amd 3200 --- I am wondering if I can but in a bigger processor as I am running 2.2 ghz and I need 2.6 for a game I would like to play. Is it possible to upgrade my processor or will the board handle it ------ or should I just start over and get a new motherboard and all ------- Thanks for any help
Anonymous
Level 2:
New Friend:
  • Expert 136 Answers
  • Posted on Aug 13, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
136
Questions
0
Helped
18651
Points
347
You can put in bigger processor, Any AMD Athlon or Sempron will do.
If you are planning to run big games, then I suggest you get
- A new motherboard with PCI Express 2.0 support
- A new processor
- A new graphics card (maybe 512 MB or 1 GB) with DirectX 11 hardware support and Shader Model 5
You may make that DirectX 10 or 10.1 and Shader 4 if you want to reduce cost.
2answers
I lost the cd driver for my sempron 3200 1.8 GHz, can you help me fix this things out so that i can configure my hardware
Here is the support hub. You can order a new driver disk through this website or simply download the drivers from the site:
http://support.amd.com/us/Pages/AMDSupportHub.aspx
Search by your model number for your motherboard.
Good luck to you!
I have installed my abit nf8-v2 motherboard into my computer but i can not get my computer to power on. LED 2 is turning on but not LED1
Please verify that you have completed the following:
  1. Connected the cables from power supply to the motherboard
  2. Connected the processor fan power connector
  3. Installed the memory correctly
  4. Connected IDE/Sata cables correctly
  5. Processor installed correctly with fan sitting correctly
2answers
Conflict adding RAM memory
you can deselect from BIOS - CAS LATENCY TIMER to value 2, or better (2,5)
2helpful
2answers
I have an AMD Athlon FX 2 dual processor and am using Core Temp to monitor the temps of which are posting 44 to 50 while using my computer. Is this normal?
I believe normal temperatures range from 41 to 95. At least from this laptop that is running a dual processor:
http://shopping.msn.com/specs/toshiba-satellite-a215-s5802-15-4-inch-laptop-amd-athlon-64-x-2-dual-core-tk-57-processor-1024-mb/itemid913517877/?itemtext=itemname:toshiba-satellite-a215-s5802-15-4-inch-laptop-amd-athlon-64-x-2-dual-core-tk-57-processor-1024-mb
Also somebody else here had the same type of question:
http://answers.yahoo.com/question/index?qid=20090207210838AA922iE
From my experience as long as its not running over 100 then you'll be fine. If you have any doubts about your computer overheating you can always apply more compound to the heatsink and also buy a bigger one where the fan runs faster to keep things cooler inside of the case and always remember to have the side doors on as well.
I just want to know if my current motherboard can
Even without any way to check the specs of your motherboard with the current information, the board will most likely have at least 2 slots available for additional memory (i am assuming by memory you mean RAM), and will support DDR, PC-3200. If you have two slots, then you're looking at a limit of 2Gb (2x1GB PC3200) because DDR modules don't get any bigger than 1Gb as far as i've seen. If you have 4 slots, then a total of 4Gb.
2answers
E2180 Vs Athlon 64 X2 5000+
depends on what you plan to do with the cpu amd are good but a 3200 may only run @ 1.8 to 3.2 ghz depending while a intel 3200 will run 3.2 ghz.
I believe intel are more stable & run cooler than AMD but AMD benchmarks on Games better but run hotter (so get a good cooling fan & heatsink both pentium / celeron d & intel dou / dual core / core 2 dou and amd x2 have 2 cores (but watch your front side bus and cache the higher the better but the more $ also) then You need a good stable mobo that supports the chip you get (I preffer asus & msi for Gamers and biostar / msi for home users)
Top Abit Computers & Internet Experts
ExpressFiX
ExpressFiX
JTR44
Level 1 Expert
Grand Canyon Tech
Grand Canyon Tech
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
