Usually thread breakage is a result of incorrect threading or the thread tension set too tight.
Install a brand new needle.
Remove the upper thread. RAISE the presser foot and rethread from the beginning (verify the threading sequence is correct).
Check that the tension is set at the midway point between the high and low numbers.
Retest. If still breaking, there are other less common problems (thread/needle incompatibility, burrs or knicks catching the thread, etc) that may be the cause. Check the following web sites:
Sewing Machine Thread Keeps Breaking
Why is my thread breaking
Sewing Machine Problem 1 Thread Breakage
