Hello There, I have the same problem with my new Pioneer Elite 110FD. While watching TV via my HDTV converter box, the power sudenly turns off and the power indicator blinks several times and the gray box with a text PLASMA DISPLAY STARTING UP appears for about 15-20 seconds... Then the display is restored. My TV is just 4 weeks old and it happened to me 2x already. It's like an intermittent error where you cannot predict when it will happen again. Pioneer Plasma Tech Support is also cluecless about this error. Is this related to any hardware problem? Any help or suggestions please?
Could be heat build up in the Plasma display unit. Make sure it has the correct space around it for proper ventilation. Also count the number of blinks on the power indicator it is a code for the reason the unit shut down. On the Pioneer PDP-5060HD I have I was getting 12 blinks on the indicator which indicated a tuner issue. Check your instruction book for info on the over heating problem if it continues. You may have a fan out.
