Hi, this is one of the largest ice machines that Hoshizaki make, with the remote air cooled condenser on the roof. As far as the code of 6 beeps, and the compressor starts and stops, you should have a error chart on one of the panels that tells you what the 6 beeps means, a dirty condenser up top that is shutting the unit off on high head or what. You need to find this code error chart, and it will direct you to the point of the problem. I have the service hand book buried in mt service van, so that's not much help.Try and check the remote condenser for a dirty coil, as the is is where you condenser fans and coil are located. It may lust need to be serviced If you have access to nickel safe ice machine cleaner and the unit has not been cleaned in awhile, this I find to be about 80% of problems with these machines. You can by a gallon at a appliance parts house or a/c parts house to clean it up. Some you will nee to do by hand, as they get slimmed up really bad and thing quit working. If you are not tied into a water softener , this is really hard on the machine. Try and look at the fans and coil up top and get the nickel safe flip the switch to the cleaning cycle, and start cleaning. This should take care of that problem. Please rate me , and be kind as I know you will and I will be here to help you. Use my user name below.
Sincerely,
Shastalaker7, A/C, Heating, & Refrigeration Contractor
When i start my ice maker up it starts with the compressor on . does not matter where u have the switch set ( ice(off)wash ) unit will only power off but unplugging it.
