Extrellita80, We apologize for what you are experiencing with your Refrigerator. We are happy to look into your concerns but we will need your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to [email protected].
SOURCE: noisy refrigerator compressor (?)
This is a compressor problem, and chances are there for this to worsen if not attended promptly.
SOURCE: Whirlpool Conquest
hi thanks for the question when you say it short cycles that's the compressor relay trying to start the compressor i would replace the relay & overload at the compressor thanks the appliance doc
SOURCE: Whirlpool GD5RHAXNT00 Side By Side Refrigerator
your problem on this is the main control in the compressor compartment. unplug your refrig then remove this control unplug all connectors and reconnect. this will probably get you working temporarily In almost every case I've seen we ended up replacing the control board. thx peyton
SOURCE: Whirlpool refrigerator side x side doors make a
The door closing cams were worn on both doors. I had to buy a cam kit that cost about $10.00 and had the parts for both doors in it, take off the doors, and replace the cams. Before taking off the door that has an ice and water dispenser, I had to turn off the water to the fridge, take off the front grill, and disconnect the water tube that goes into the door (as the tube is threaded through the door cam). After replacing the door closing cams and reassembling, there is no longer a popping sound.
SOURCE: Freezer not freezing, refrigerator warm, hear clicking sound
The overload/relay on the compressor is shorted . This is the piece with 2 or 3 wires connected to it , mounted on the compressor . The part # you need is 8201786 . Complete mounting instructions , come with this kit . Easily replaceable .
