It is possible that your screen voltage/ grid voltage goes down and so the retracing lines appear with a whittish blank screen. So ypou will need to disconnect th power before opening the set and checking on the HT section. Check for the bias voltage , usually a capacitor of 10mf to 22 mf/250V could be defective. You can loop a capacitor in series and confirm Please use a multimeter to check for voltage in the crt base. An open resistor or partially getting open could also be the case. You can also check for dry or loose connection inthis HT section. I hope you try or seek help if not familiar. Good day
Classic bad picture tube! End of natural life for that make/Model.
The current sensing circuit is turning the video on/off.
The orangey look also indicates CRT no good.......T.
