Your display may be flickering for several reasons. You will want to take the following steps to rule out the most common reasons for the display to flicker:
1. Reseat all cable and
connections to the television from your devices. Physically remove the
cables from both the television and the device and reconnect them.
2. Check your Advanced
Video settings in the Vizio TV menu some of our Vizio televisions will
allow you to adjust the following settings under the Advanced Video
settings:
Ambient Lighting
Backlight Control
Advanced Adaptive Luma
If you have any of these options available please turn all of them off to see if this resolves the display flickering.
If the above steps have not resolved the issue please take the following steps in the order presented:
1- Power off TV
2- Unplug TV from outlet
3- Press and hold in the power button on the TV for 30 seconds (while it is unplugged from the wall)
4- Release the power button
5- Plug in the TV into a different outlet
6- Power the TV back on
There
is also a factory reset option in your menu under the SETUP section. It
will say either "reset all settings" or "system reset". We recommend
that you reset all settings as well to see if this resolves the issue.
If this does not resolve your problem please contact our technical for
further assistance.
If the line stays in the same spot when changing the above settings please contact our technical support.
