You either don't have them in the needle holes and or your not tightening the screws to hold them in
You probably are putting the needles in the wrong holes. The two holes you want the needles in for the basic overlock stitch are holes C & D which are to the FAR RIGHT SIDE of the needlebar not the main 5 hole piece that you see first. These are used for the cover stitch only. When you insert your needles (flat to the back) or remove them MAKE SURE you tighten up the screw immediately so you don't forget to do it. If they are loose and fall down in your machine good luck finding them! Hope this helps you.
