Focus problems
There are two likely reasons for the blurry pictures. One possibility is, as you surmised, a slow shutter speed. Try mounting the camera on a tripod or other stable support. You might also try turning on the flash.
The other reason is focus, or lack thereof. You didn't specify what cameras you have, but if they're Coolpixes, they most likely have a close-up or macro mode that will allow the lens to focus closer. If you're using a DSLR, you will need some other way to focus closer. Macro lenses, extension tubes, and close-up filters are three ways of achieving this.
Hi my name is sunil. i have the same problem in my canon S51S powershot. i tried taking macro shoot but i could not focus into the subject, is not possible to take without an macro lenses..??? r is anything else i should do...??? please reply to my email id [email protected]
I had the same problem and then by chance I got it in focus and then held the shutter down half way and that seemed to work. I also noted that you have to be 4 inches away when using the macro and that was important any closer and it is blurry. I use a tripod or I am very steady when I use the supermacro
