Ovens Logo
Posted on Aug 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Jenn Aire model JJW8530AAW built in oven door stays open 2 inches. A repair man came to fix it and now it's worse. close the door and it pops back open about 2 inches and the light comes on.
Anonymous
Level 3:
  • Master 1,891 Answers
  • Posted on Aug 11, 2010
Anonymous
Master
Level 3:
Answers
1891
Questions
0
Helped
408975
Points
5205
Both hinges must be replaced . ck back with repair service as this is not a tuff job .mm
Jenn-Air model WW27430P. After heating to set temperature and baking for 8 to 10 minutes, why does it shut off?
It's faulty and in some sort of self protect mode. You need a service call or you can try some of the fixes here.
FIXED - WW2780 Jenn-air oven keeps shutting off ...
www.applianceblog.com > mainforums > threads > ww...
Feb 15, 2012 - Hi.... I have a Jenn-air oven model WW2780 that keeps shutting off after being turned on, almost always during the preheat. From what I have ... Missing: WW27430P ‎' Must include: WW27430P
Jenn Air Range Stove Oven - Oven Won't Turn Off - Repair ...
www.repairclinic.com > RepairHelp > Jenn-Air-Oven-...
Here are the most common reasons your Jenn Air oven won't turn off - and the ... Enter model number to search for the required part specific to your product.
HOW-TO: Jenn-Air Oven WW27430P Door won't close
www.appliancepartspros.com > repair-help > ww27430...
Door won't close is the most common symptom for Jenn-Air WW27430P. ... I have a Jennair jjw9630cas double wall oven, and after a few years I noticed that the light would not go out, first in the bottom ... Door pulls shut and li8ght stays off.
HOW-TO: Jenn-Air Oven WW27430P Won't start or doesn't start
How to Replace Oven Temperature Sensor Kit for Jenn-Air WW27430P Won't start # ... Jenn Air stove JDS9860CDB00 error code 1d11 oven not shutting off. ... Very easy on this and other models with this sensor-- just two screws holding it in ... Rating: 5 · ‎123 reviews
Nov 17, 2020 • Ovens
Oven door falls open and will not close tight on my Jenn-air Single oven Model #SVE47100w
The hinges and receivers would need to be replaced on this. The hinges are part number 71003351 you need 2, they go inside the door, so the door would need disassembled.
The receivers (hinge receptacles)are part number 71002206 you need 2 also, these go on the side of the oven. You will need to pull the oven out a few inches to gain access to these
2answers
Door will not close all the way...
This is likely one of two problems. Either the fiber gasket is getting in the way or if it is like ours one of the hinges is broken or bent. The Hinges can be replaced for about $13 a piece and is not a difficut job. On our the oven was also opening more then 90 degrees and wouldn't close more then to about 1.5 inches away from full closure.
One of the oven doors does not close tight so heat escapes. It is a Jenn Aire electric double wall oven model number JJW9627DDS.
Sounds like the oven door hinges have worn. If door is not obstructed in any way and will fully close when pushed but open about half a inch when released then it will be the hinges. Not sure of cost of spairs. I believe this to be a John Lewis Model. If it has a Enr no inside the door or inbetween the door hinges then I could give you price on spares
2answers
Oven Door Jen-Aire Single Oven won't shut all the way.
you have bad receviers probably. did you set anything heavy on it latley? sometimes you can realign the door by sticking a peicee of 2x4 between the door and the frame and closeing the door to pop the hinge out a little thatt sometimes solves the problem with out haveing to replace the hinges and the receivers
3helpful
No digital display oven works
We own a Jenn-Aire model W27400W oven. The display module has gradually gone dim over a period of several months prior to the end of the warranty, and the display is no longer visible. It is apparent that several Jenn-Aire oven models use the same display. Does Anyone else have the same problem, and If so, are they willing to join a class-action suit against Jenn-Aire with us?
Steve Patterson
303-256-8494
[email protected]
Jenn-aire JJW8530dds
It might be because when the door was completely removed ( which they do rather easily for repairs and moving) it wasn't put back properly.
I would suggest you remove the oven door and re install.
You do not remove any screws or anything like that to remove the oven doors.
When you have the oven door open squeeze each hinge and shift then both outwards it will release the door from the hinge, the hinge stays on but the door will slide off the hindge. Afterwards check the alignment and reinstall the oven door
Need a manual to operate five year old Jenn Aire wall oven
Jenn Aire model tag are usually at the opening of the door, or may have to pull unit out...be sure to check around the door before pulling out.
1helpful
5answers
Jenn-Air 30 in. Electric Wall Overn jjw8530ddw
lendebr is right...
Same problem here on combo microwave and convection oven. The hinges are a horribly wimpy design. Jenn air has a replacement part thats helps..but the replacment hinges will do the same thing in very short order. 1 month after I fixed ours my sister in law opened the oven door and let go of the door when it was about 2/3 open and that was all it took to tweak the new hinges so the door doesnt close all the way again. i should have clued in when the girl at Jenn air sent me three sets of replacement hinges. I thought it was a mistake..turns out she knew it wasnt going to fix it permanently.
The moral is that Jenn air appliances are POS and I will not ever buy anything from the again..But I will tell everyone I possibly can not to buy anything from them.
2answers
Jenn -air oven w30400p
Do you mean the service engineer replaced the hinges?
If so call him again and tell him he didn't fix it. The service engineer should come again and fix it for free if there's any justice in this world.
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
