SOURCE: UNIDEN 5.8 GHZ CORDLESS PHONES
Registering Handsets to the Base
Whichever handset you choose to charge in the base is automatically
registered to the base. Any additional handsets must also be registered to
the base before you can use them.
Be sure both handsets are fully charged.
One at a time, place each handset in the base. The charge/in use LED on
the base begins to flash, indicating the base is registering the handset.
Wait for at least five seconds, then pick up the handset and press
[talk/flash]. If the display shows TALK, the handset is registered. If not,
place the handset in the base to try again.
Press [end] and continue with the next handset.
Note:
Once both handsets are registered, it doesn’t matter which
handset is placed in the base or the charger.
When you charge the handsets, Caller
ID summary screen and the name of
the handset appears.
This can be find from uniden website.
http://www.uniden.com/pdf/DXAI4588-2om.pdf
SOURCE: remote retrieval of messages, uniden dect 6.0 cordless
30 seconds with a search engine got this page http://www.uniden.com/index/manuals_results.cfm?cat=59
Put in your model number and you're good to go.
Carl
SOURCE: Uniden cordless phone. No dial tone.
Hi peddler65, did you plug your phone into another area to see if there is a dial tone. Then if not call the phone company or find the D-mark (where your dial tone ) comes into your home and put a jack on that and plug a phone in with all phones
in the house unplugged.
Thanks.
SOURCE: uniden dect 1588 won't dial out. dial tone
press "menu", "global setup", "dial mode", choose "pulse".
I dont know why it works, but it does!
