SOURCE: Olevia t.v.
comcast has a new remote with new codes for Olevia (5 digit codes replace the old 4 didget) you need to ask for the dvr 3 with the RED select/ok button. The problem is that the codes still dont work for many of the olevia sets. If this does not work for you than the ONLY other option is to buy a programable remote. You will get no help from Olevia and I have spent hours trying to solve this problem. I got the new comcast remote, tried the 3 Olevia codes and none worked but you can give it a try.
SOURCE: QUESTION ABOUT PROGRAMMING CABLE REMOTE TO T.V
the code for olevia for cox cable is 1610. Hit tv then hold setup till light blinks twice. release setup. enter 1610 and wah lah
SOURCE: how to program comcast remote with my toshiba 19hlv87
with comcast remote with red ok select switch the toshiba codes are 11256 most likely, other codes are 10154, 10156, 11265, 10060, 10650, 10845, 11156, 11356, 11656, 11704
with comcast remote with grey ok select swithc the toshiba codes are 0154, 0156, 0060
Dale
