SOURCE: LEAKING DISPENSER DRAWER
Refer to your manual regarding the dispenser tray. You could try using a tooth brush to clean out dry detergent, which could be blocking the flow of water. You can take out tray to clean, ref manual.
SOURCE: soap won't dispense
the problem is quite easy. There are 2 valves on top of the dispenser box. When disconnected from power source please check whether the connections are secured. Sometimes the valve connections shake lose during transport or opperation. Also check the dispens drawer for clogging . This should be fixed easily. If you leave the top cover off and plug the machine in and start opperation there should be 120V on the valve connectors. If there is and water stil does not come out the valve is faulty and you have to order a new one.
( ) indicates recommended quantity
Valve assy, inlet
SOURCE: frigidaire clothes washer model #FWT445GES1.
I was having this problem. I thought the door catch was damaged but looked it up online and saw that it was intact. I was just about to call the repairman when I took another look and found that the rubber seal around the door was not properly seated. Duh! Almost cost me $100+ and lots of humiliation.
SOURCE: Can you use Oxyclean along with detergent in front loaders?
I use 2 Tablespoons of Liquid Detergent and a 1/2 to 3/4 scoop of Oxyclean and I have had good results in my Front Loader. Clothes come out very clean and there is no residue on the inside of my washer.
Hello royal37 - Hi - The dispenser drawer could either be cracked or have a broken latch due to interference between the drawer front and top panel. Contact a professional to move forward accurately and might possibly need to order a service kit (PN: 137146000/part number may be different depending on your model number).
Hi Hulo - Sounds like the dispenser detergent drawer latch may possibly be damaged or broken. Consult a professional to accurately diagnosis the unit and assist with the repairs.
