<p>If your <b>dishwasher
does not seem to be cleaning well</b> anymore and you are getting<b>
residue and film left on your dishes</b> then you need to read this.<br />
<p><br />
<br />
<p>Since July of 2010
the US Government has mandated that <b>dishwasher detergents</b>
contain no more then 0.05% phosphates in them. The Detergents before
this had contained up to 8.7% phosphates. The restrictions were for
16 states but many companies then dropped the phosphates from
detergents to all states...<br />
<p><br />
<br />
<p>Now if you are
having the <b>scum, film, and white residue problems</b> in your
<b>dishwasher, </b>there is hope.<br />
<p><span>There
is a product that you can buy that will compensate for what the
makers of the </span><b>dishwasher detergents</b><span>
have left out. This product as commonly know as </span><b>TSP</b><span>
or </span>(<b>Trisodium Phosphate</b>).<br />
<p>By adding this to your dishwasher, you
can manually add back the phosphates to your dishwasher and enhance
the cleaning process.<br />
<p><br />
<br />
<p>Now the nest question...how much TSP do
I add to the dishwasher?<br />
<p><br />
<br />
<p>For many dishwashers, waters, and for
normal loads you will find that a tablespoon or two is all that you
will need. For very hard to clean dishes and for some types of water
you may need to add up to a 1/3 cup of TSP.
<br />
<p><br />
<br />
<p>If you are having problems with your
<b>dishes not getting clean</b>, a <b>black or scum film</b>, or
<b>white residue</b> being left on your dishes at the end of the
cycle, then I would start with a tablespoon or two and then adjust
from there. Figure out how much you need to add to you dishwasher to
make your <b>dishwasher detergent </b>work correctly for you again.<br />
<p><br />
<br />
<p>To best part is that you can have <b>clean
dishes </b>coming from your dishwasher again!!<br />
<p><br />
<br />
Most dishes in any dishwasher are still wet when cycle is finished. The heat built up in the dishes during the washing cycle is what causes the water to evaporate when the machine stops.
If you want to accelerate the evaporation, simply open the door very slightly so that as the hot air escapes it causes the dishes to dry quicker.
There are some things you can try, however, if your Maytag dishwasher is not getting your dishes as clean as you would like. Maytag recommends several processes for fixing this issue with your dishwasher.
Do not run your Maytag dishwasher while hot water is being used in other parts of your home, such as washing clothes or showering. Hot water is needed for your Maytag dishwasher to properly clean dishes.
Run water in the sink in your kitchen until it gets very hot. Then, turn on your Maytag dishwasher. This will ensure that the water cleaning your dishes is the hottest possible temperature.
Clean your Maytag dishwasher to improve the cleaning results for dishes. Run your dishwasher on a short wash cycle and wait for it to fill up with water. Stop the cycle and add about 1/3 of a cup of rust remover to the dishwasher and finish the cycle. Run your Maytag dishwasher through one normal cycle with regular detergent to finish the cleaning process.
Check your detergent. Old detergent or those that have been exposed to moisture can be clumpy. This detergent will not clean your dishes as well when loaded into your Maytag dishwasher. Purchase fresh detergent.
Use extra detergent when washing dishes that have a lot of built-up grease or food particles. The extra amount of detergent is needed to get your dishes clean. Choose a long cleaning cycle to clean these dishes.
Fill your Maytag dishwasher properly. Dishes should not be stacked on top of each other or excessively crammed into your dishwasher. This will keep the dishwasher from adequately cleaning all areas of your dishes and from rinsing them thoroughly.
Most dishwashers are plumbed to the hot side of the hot water side of the faucet. This should provide hot water for washing the dishes. Perhaps this dishwasher was plumbed to the cold water side by mistake.
Most dishwashers have a heating coil most of the way around under the bottom sliding/rolling dish rack. The heating coil may not be working, which would be consistent with the dishes not drying at the end of the cycle. Possible causes include incorrect setting selected on control console (push buttons) or timer, heating coil disconnected from electrical source at one end or both ends, faulty control circuit inside the timer, faulty wiring between the timer/control circuit and the heating coil, burned or pitted contacts in the control circuit.
After you run a load of dishes put 1cup of CLR or vinegar (white) and run a quick wash.no dishes,after running dishes clean out spray arm and clean strainer,use a rinse agent like finish, and spray off dishes before loading.About 35yrs. ago I use to be a dishwasher as one of my first job's and if you did'nt spray the dishes and scrap them off before loading,the dishes would not come out clean,And after each shift the dish washer would be cleaned out.
Well, that usually happens if the water in the area has too much alkali metals, such as calcium and magnesium.
Try putting some salt together with the detergent before you start the cycle.
And if it still does, try washing the finished dishes again with clean water, i mean, without detergent...
Cold water is the only type of water that fills your tub. The machine looks like it stops because it is waiting for the water heater to heat the water in your machine to a highert temperature, enough to get your dishes clean.On that model you can't say very often that your dishes don't get clean.
Recommend that you run another cycle with no DW soap aded, waiting until the dishwasher has filled with hot water and begins to do the first wash cycle. Then add 1/2 cup of bleach to the water and close the door. Allow the cycle to finish. Run it normally with a standard load of dirty dishes. Note: These high efficiency dishwashers count on the "dirt" of the dirty dishes to help wash/clean the dishes. Recommend you not rinse/wash the dishes before you put them in the dishwasher.
Watch for any occurrence of the black dots and repeat the bleach treatment.
It is very common that high eficiency, low water using dishwashers take longer to finish all cycles. The best way to "hurry" the washing is to make sure that the water heater is providing hot water of at least 120 degrees. But no hotter then 140 degrees.
If the dishwasher runs even longer, check to see is the dishwasher is actually connected to the cold water line. This dishwasher can be run from cold water but the water heating phase in the cycles will add much time ti the entire cycle.
This unit has a sensor that detects the detects the water clarity towards the end of the wash cycle. Rinsing the dishes may speed the load a little, but encourage not to go crazy on the rinsing because the dishwasher actually counts on the food particles to help clean the dishes.
Also, note that the final (third) blinking light means drying. You can simply open the door anytime after the final draining and power off the dishwasher, allowing the hot dishes to air dry.
Hope this helps. Please resply with your findings. Thanks!
