click start control panel administrive tools scroll to cd/dvd drives connect this dvd rw then see if your drive there if not check the leads that attach from the dvd drive to the computer make sure they have secure connections and are seated properly or you might have to activate add new device wizard click start control panel you will see add a new device this may vary depending on your operating system
hope this helps
First, open the external casing.
You'll find an "internal" CD/DVD drive, connected to an adapter, and the adapter connects to the USB cable.
Now, look at the adapter -- it could be a "parallel-ATA" interface, or it could be a "SATA" interface. The new CD/DVD drive will have to have the same connectors (data and power) as the adapter.
You might have to exchange the SATA device for a Parallel-ATA device.
If you have a parallel-ATA CD/DVD drive, look at the back of it.
There is a tiny jumper, and a few labelled settings:
* MA(ster)
* SL(ave)
* C(able)S(elect)
Move the jumper to the 'MA' setting, so that the USB-adapter will recognize the CD/DVD drive.
Connect the drive to the adapter.
Close the case.
You're good to go!
You definitely should call LG--your new gaget isn't working, and it is under warranty. Or try going to their website to see if they have any software upgrades--sounds like you have a bummer, and perhaps a reinstall from their website will do the trick.
