Computers & Internet Logo
Posted on Aug 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the apostrophe on my windows xp keyboard? It is not the sintle quote per my publisher.
David Rimer
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Sep 27, 2013
David Rimer
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
373
Points
PC Keyboard: The apostrophe is located just to the left of the enter key. " and ' are there. Good luck.
PCShare.Com
Level 2:
  • Expert 54 Answers
  • Posted on Aug 10, 2010
PCShare.Com
Expert
Level 2:
Answers
54
Questions
0
Helped
15006
Points
158
Http://en.wikipedia.org/wiki/Apostrophe, according to it, right of colon and semi-colon.
2answers
How can i type latter Apostrophe with dell laptop
Apostrophe key is next to the enter key
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
1helpful
The apostrophe key on lenovo 3000 will not work how can i get it to work
Sounds like your keyboard has an issue if that is the only key that does not work.
Try using a virtual keyboard that pops up on the screen and you just point and click when you need the apostrophe.
Go to www.google.com and in the search box type: "download.cnet.com" (without the quotes). Click the link to go to the site and look on the left side when the site opens up and you will see a gray area that says FIND SOFTWARE. In the white search box under Find Software type: "Virtual Keyboard" (without the quotes) and click the mirror to search. When the search results come back look for FREE VIRTUAL KEYBOARD. Download and Install it. It's totally FREE. Also uncheck anything that pops up other than the license agreement during the download and installation. You only want the Free Keyboard and not the other junk.
You can use it to solve your keyboard problem. Just open up whatever it is you want to type on such as the web address in an browser, a word document, etc., then open the Free Virtual Keyboard and it will sit on top of whatever you were doing. You can move it around so that it is not in your way also.
How to use accents when writing in Spanish in a Dell Precision m4500 laptop?
On Windows XP
  1. Log On
  2. Click the Start button
  3. Click on Control Panel
  4. Click Regional and Language Options - a new window will pop up
  5. Click the Languages tab
  6. Click on the Details button
  7. Click the Add button - a new window will pop up
  8. Select United States-International (keyboard layout menu)
  9. Click OK
  10. Click Apply
  11. Read the instructions for "Using the U.S. - International Keyboard" below.
Note: You will now have a keyboard icon on the taskbar (usually on the right side). To switch between keyboard layouts click the keyboard icon on the task bar and choose which layout you want to use. Changing the keyboard layout will only affect the log on profile used. No other users will be affected.
Windows Vista
  1. Start-->Control Panel-->Clock, Language, Region-->Change Keyboards
  2. New Window: Click the Change Keyboards button
  3. New Window: Click the Add button
  4. Select United States-International keyboard
  5. Click OK
  6. From drop down menu (Default Input Language) select United States International
Using the U.S. - International Keyboard If you followed the above directions carefully, your keyboard will now react slightly differently than it did before. First of all, notice that if you strike the single apostrophe (') key, nothing happens. To type the single apostrophe now, you must strike the single apostrophe key and then strike the space bar. When you strike the spacebar, the apostrophe will appear.
The next thing to note is that the quotes (") key behaves the same way as the apostrophe key. You must first strike the quotes key and then strike the space bar in order to create the (") symbol. These two minor inconveniences are more than made up for by the ease with which you can now type the special characters.
To type the special characters, two keystrokes are required. To type the ?, you need only strike the apostrophe key and then the letter a. The other characters are just as easy:
  • ? = ' + a
  • ? = ' + e
  • ? = ' + i
  • ? = ' + o
  • ? = ' + u
  • ? = ~ + n
  • ? = " + u
To type the special punctuation characters, you need to hold down on the Alt key while you strike the appropriate punctuation mark. On some keyboards, only one of the two Alt keys will work for this.
  • ¡ = Alt (hold down) + !
  • ¿ = Alt (hold down) + ?
Using Cryptic Codes If, for some reason, you don't want to change your keyboard, you can always type in the troublesome cryptic codes. Using this arcane system, the following codes apply:
  • ? = Alt + 0225
  • ? = Alt + 0233
  • ? = Alt + 0237
  • ? = Alt + 0243
  • ? = Alt + 0250
  • ? = Alt + 0241
  • ? = Alt + 0252
  • ¡ = Alt + 0161
  • ¿ Alt + 0191
When using this utterly out-dated system, there are two important things to remember. First, when you type in the numbers, some keyboards require that you use the "numeric keypad" located to the side, rather than the numbers along the top. Second, on some keyboards, only one of the two Alt keys will work for this.
When I press apostrophe quotes they don't appear. But when I press the button a second time, then I get double ( "" ) and have to backspace to get single quotations ( " ) How do I fix this?
Download the Microsoft settings utility for this keyboard and check through the options settings, especially for "smart quotes." The smart quote, if enabled, may not show up at either end of the quoted phrase until you press the apostrophe/quote key the second time; then both will show in their proper places, and one of the quote marks will be inverted (a nice style touch, if you want it).
4helpful
I cannot locate the apostrophe on my keyboard.
Linda,
The apostrophe is depicted by the single quote, ' . Or I f you want it could also be depicted by ` which is just below the Esc key. You could use either.
1helpful
My quotations and apostrophe key is typing an e. How do I change it back?
sorry but you cannot change it back... you need to buy another keyboard so that you can use your computer again... there a loose connection in your keyboard... hope i help you with that...
1helpful
Symbols gone crazy
The keyboard appears to be defective, but if you replace it and you still have issues, then the matrixing chip on the motherboard is bad and you will have to change the motherboard as well. Let me know, and vote.
3helpful
Messed up keys
try hitting the left alt and the left shift button together, then try it out by pressing shift question mark. I had the exact same problem and i think you can alternate between french and english keys by hitting these two buttons together.
Grand Canyon Tech
Grand Canyon Tech
