Computers & Internet Logo
Anonymous Posted on Aug 10, 2010
How to change the time format from 24 hour to 12 hour in windows 7 thank u.
mukhtar21 shaikh
Level 3:
President:
  • HP Master 2,022 Answers
  • Posted on Aug 10, 2010
mukhtar21 shaikh
HP Master
Level 3:
President:
Answers
2022
Questions
Helped
668877
Points
5817
  • Click on Start > Control Panel, and choose Regional and Language Options.
  • Click the Customize button underneath the Standards and formats section.
  • Click on the Time tab and change the time format to H:mm:ss (note the uppercase H) and press OK
  • Below that button, you’ll also see an example of how each setting is currently configured for Number, Currency, Time, Short Date, and Long Date.
  • Type uppercase H or HH to Display time in a 24-hour format
  • Type lowercase h or hh to Display time in a 12-hour format
  • Type two characters, HH or hh to Display leading zeros in single-digit hours
  • Type a single uppercase H, or lowercase letter, such as h, m, or s to suppress the display of leading zeros in single-digit hours, minutes, or seconds
  • Type lowercase t to display a single letter to indicate AM or PM
  • Type lowercase tt to display two letters to indicate AM or PM
  • Type single quotation marks (’) around text to display text
  • Testimonial: "thank you sir..."
    wayne walker
    Level 3:
    • Master 779 Answers
    wayne walker
    Master
    Level 3:
    Answers
    779
    Questions
    Helped
    328791
    Points
    2177
    How do i reset the 24-hour time to 12-hour time on a Brookstone alarm clock
    Dozens of models to choose from. All questions on Fixya need 'make model (what it is)' as the first 3 words.
    Here are some guesses. The 'control cover' is where you put the back-up battery.
    To change the 12/24 hour time format, open the CONTROL COMPARTMENT COVER on the bottom of the clock and adjust the 12/24 TIME FORMAT switch to the desired format .
    Self-Setting Clock - Brookstone
    Instruction Manual - Brookstone
    Brookstone https://manuals.brookstone.com > ... PDF 12/24 HOURS TIME DISPLAY SETTING 1. The "12h" or "24h" will start flashing in LCD2 (Default setting 12h). People also ask
    How do you convert a 24-hour clock to a 12-hour clock?"); display: inline-block; height: 24px; width: 24px;"> How do I change my alarm clock to 24-hour clock?"); display: inline-block; height: 24px; width: 24px;"> What is 12.30 pm in 24-hour time?"); display: inline-block; height: 24px; width: 24px;"> Feedback
    Setting The 12/24 Time Format; Setting The Daylight Savings ...
    ManualsLib https://www.manualslib.com > ... > User manual
    Brookstone TIMESMART Self-Setting Clock Radio Manual Online: setting the 12/24 time format, Setting The Daylight Savings Time. The 12 Hour Format Is Set As ...
    1helpful
    2answers
    How do i change from 24 hour format to 12 hour format
    please move to the section of the device where you the the time and look for a symbol with 12 associated with it. You might have to scroll through for a few seconds before you see it but usually selecting that symbol updates the time-format of your device so that you don't have to use "army" time anymore.
    Thank you.
    How do I change my Brookstone 399923 clock from military (24 hour) time to standard (12 hour) time please?
    Try this
    Setting the 12/24 time format The 12 hour format is set as the default. To change the 12/24 hour time format, open the CONTROL COMPARTMENT COVER on the bottom of the clock and adjust the 12/24 TIME FORMAT switch to the desired format. Close the CONTROL COMPARTMENT COVER.
    How do I change from 12 hour format to 24 hour format ?
    In mobile u can go to setting>date and time> there is is boxx showing time format uncheck the box to 12 hour format
    Thanks...
    Jul 04, 2016 • Watches
    Press the MODE button 3 times, the hour digits blink.
    2. To set hour, turn the VOLUME wheel to obtain a desired value.
    Note: Make sure the hour is set so that the AM or PM indicators are displayed correctly.
    3. Press the MODE button again, the minute digits blink.
    4. To set minute, turn the VOLUME wheel to obtain a desired value.
    Set 12/24 Hour format
    5. Press the MODE button repeatedly to enter 12/24 hour format setting mode, "H12" appears and flashing.
    6. To select H12 (12Hour) or H24 (24 Hour) format, rotate the VOLUME wheel.
    Exit setting mode
    7. To save all settings and exit the setting mode, press the SNOOZE button.
    2helpful
    2answers
    The digital clock seems to be set to 24 hr insted of 12 hr time
    No Problem here ya go
    To change the clock to 24-hour format:
    1. Press and hold the CANCEL and Delay
    pads for three seconds.
    2. Press the More+ or Less - pad to select
    12 or 24 hour.
    27helpful
    3answers
    Timex Indiglo WR 30M
    NOTE: 12/24 HOUR TIME IS SELECTED BY PRESSING RESET/LIGHT ONLY WHEN THE HOURS MARKER IS
    FLASHING. THE “A” OR “P” WILL DISAPPEAR WHEN THE
    WATCH IS SET TO 24-HOUR TIME.
    Clock format
    24 hour mode is all there is. Time to learn military time.
    Top HP Computers & Internet Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
