You can change the number of times the phone rings before the unit answers calls.
You can select 2 to 7 rings, or “Auto”.
“Auto”: The unit answers after 2 rings when new messages have been recorded, and
after 5 rings when there are no new messages. If you call your phone from
outside to listen to new messages, you will know that there are no messages when the phone rings for the 3rd time. You can then hang up without being charged for the call.
1 Press OK.
Select “Answer System”, then press >(Right navigation button).
2 Select “Settings”, then press >.
3 Select “Number of Rings”, then press >.
4 Select the desired setting, then press >.
5 Press End button
Thank you
Was helpful, but instructions did not match my KX-TG1840AL unit.
1. Press menu/OK button
2. Scroll down until reach "initial setting"
3. Scroll right to "set answering"
4. Scroll right to "ring count"
5. scroll up to increase from 4 to 7.
6. Press black button to the right of the menu/OK button.
7. This saves the setting.
