Big Green Egg Extra Large - XLHD All-in-One Grill / Smoker Logo
Posted on Aug 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cannot get the extra large big green egg hot enough it goes to 300 but really no further. With my leaf blower- blowing air into the intake i got it up to 400 but no further- this is the second time it did not get hot enough the dealer sold me some charcoal from hawaii should i use only big green egg charcoal
Gary Kenady
Level 2:
  • Expert 140 Answers
  • Posted on Aug 19, 2010
Gary Kenady
Expert
Level 2:
Answers
140
Questions
0
Helped
45224
Points
157
Yes use ONLY Big Green Egg Charcoal If you use anything else you can damage it
  • Rolltide780 Dec 01, 2010
    My XL Egg wouldn't heat past 290 degrees and I found that the soot from the charcoal was blocking the air intake holes underneath. Fire is about fuel and air and with the holes blocked, my Egg wasn't getting the air it needed to burn. The lump charcoal produces a soot that looks like sand and will clog the air holes over time.
    The solution was easy: I used my ash tool to vigorously rake the cool lump charcoal (and I use only hardwood lump charcoal--but of various brands) around and around making sure that I raked the area inside the fire box that is directly over the air holes. This forced the soot down into the area where I could rake it out. This process took 3-4 minutes and after this process I was left with "clean" charcoal and clear air holes.
    The result? My Egg now gets hot like it used to and cooks beautifully.
    I've used Green Egg charcoal--but also Royal Oak Lump charcoal (which makes the Egg charcoal I believe) and the Cowboy lump charcoal. All work fine as long as you have an Egg that breathes.
    Hope this helps.
  • sharkman1 Mar 26, 2011
    If you will get a bbq guru computerized fan you will never have a heating problem and you will never miss getting perfect results.
    You do need to take the insides, fire ring and firebox, out every once in a while and clean around the firebox and fire ring and of course keep the ashes raked out of the bottom. Be very careful with these items as they will break but I have never had one do it and have done this to my xlbge many times. Around the air intake you can use the bge ash tool to reach between the firebox and the outside wall as ashes tend to build up there often. Any good quality lump charcoal will give you high heat so the heat source is up to you. I was never told that I must use bge charcoal.
How to repair Toro Super Blower no longer blowing, only vacs/intakes?
when you remove the vac part there should be another "grid type" part that snaps in place of the vac tube. This engages the safety switch and keeps your fingers out of the impeller.
Big green egg
I converted BGE to gas using parts from popular smoker web site. Please let me know if you are interested in parts list
1helpful
Exterior paint is pitting (chipping)
You didn't mention how old your Egg is, but if it's been sitting out, uncovered in the weather for a couple of years, that's probably playing a role in why it's chipping. Especially, if freeze/thaw weather.
If none of the above is the case, the fired finish may have had air bubbles in it. If the Egg is no more than a year old, contact the manufacturer concerning this. They are good folks and will try to do their best to help you.
Hope this helps and Happy Grilling.
2answers
How do I clean the vent filter for handheld leaf blower??
It will all depend on the material the filter is made out of. If you could post the brand and model, I could get a better idea. If you end up forcing air through it, be sure to blow the air OPPOSITE of its natural intake. You dont want to force dust further into the filter. Of course your safest course of action is to replace it if its really bad. I have seen (but will never recommend) people spraying carb cleaner into the felt filters, and then blowing air opposite of the natural intake(from the interior side). It gets felt filters extremely clean, but they will break down quickly. If it is a foam filter, detergent and hot water for a few min will work. Some foam filters need to be re-oiled (such as lawnmower filters) but I have never seen an oiled foam filter on a leaf blower.
Nov 21, 2010 • Garden
5helpful
3answers
Only runs on choke, will not rev-up. took exaust off did not change, fuel is filter clean, plug has been cleaned, new fuel and let idle till it got hot, still will not rev-up
Your description sounds like fuel restriction in the main circuit. Sometimes you need to soak the carb in carb cleaner and then blow out passageways with compressed air.
There is one "cheat" but it involves some higher throttle, and that is you remove the air filter, rev up the unit and briefly place palm over the intake. Sometimes this is enough to pull the obstruction free.
1helpful
2answers
I have a Challenge GBV180 Garden Blower Vacuum. I can only get it to blow ..does this model vacuum and if so how do the bits attach ?
remove the blower tube by turning anticlockwise. remove cover from air inlet same way. attach large diameter suction tube to air inlet (has to fit correctly as this is where the safety switch is) attach collection bag to air exhaust opening (where you removed the blower tube from)
Oct 15, 2010 • Garden
I have a large green egg. just replaced gasket and having trouble with the lower band. it wants to slip upwards and does not fit properly-thus allowing air to leak out. I put in a new bolt and tried to...
The early bands had a locating pin in nthem but this just cracked off some ceramic when removed. The bands are genrally never entirely right. You really have to tighten them as much as possible
11helpful
4answers
Craftsman leaf blower/vacuum
There is a round grille on the bottom of the unit. Insert a flat blade screwdriver into the latch to release it and reveal the vacuum opening. You should have a two-piece intake pipe that will attach to the opening.
The collection bag attaches to the smaller outlet where the blower pipe used to be (unscrew the wing nut to release the blower pipe). The bag clips onto the hooks at the base of the opening.
1helpful
2answers
The leaf hog BV4000
Put the switch in the center off position. That allows you to press the big black button in the front and take the vacuum attachment off. Replace the vacuum with the blower attachment and you should them be able to blow rather than vacuum.
Top Big Green Egg Grilling Experts
Paul Carew
john h
Are you a Big Green Egg Grilling Expert? Answer questions, earn points and help others
